Scholar ronnywebers
Vivado 2015.3 uninstall fails (msvcp110.dll is missing)
I try to uninstall Vivado 2015.3 from my pc, (win 7 64 bit), but I get the following error :
the program can't start because MSVCP110.dll is missing from your computer. Try reinstalling the program to fix this problem.
I checked in C:\windows\system32 and the MSVCP110.dll is there
I also tried reinstalling the VC++ 2010 redistributable SP1 x64, but didn't fix this error either.
Trying to add or remove components via the help menu results in the same error dialog (MSVCP110.dll is missing)
Observer bach.long
Re: Vivado 2015.3 uninstall fails (msvcp110.dll is missing)
I ran into the same problem trying to uninstall Vivado 2015.3 from a Windows 7 SP1 64-bit machine.
I worked around it by copying all the DLL files from the root of the Vivado 2015.3 installation tarball (Xilinx_Vivado_SDK_2015.3_0929_1.tar.gz), i.e.
msvcp110.dll
msvcr110.dll
vccorlib110.dll
to
C:\Xilinx\.xinstall\Vivado_2015.3
(I don't know if all three DLLs are required, but it did no harm to copy them all.)
I was then able to uninstall Vivado with
Start -> All Programs -> Xilinx Design Tools -> Vivado 2015.3 -> Uninstall Vivado
Hope this helps.
You can manually delete the Vivado 2015.2 files.
Satish
@ronnywebers
Try below link:
http://www.microsoft.com/en-us/download/details.aspx?id=30679#%3Chttp://www.microsoft.com/en-us/download/details.aspx?id=30679
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
Scholar ronnywebers
I prefer not to do it this way ... uninstalling normally does a lot more, like cleaning up registry, removing user settings, ...?
Scholar ronnywebers
and sorry, I meant 2015.3, my 2015.2 does properly uninstall if I want to. It's only the 2015.3 that does not want to uninstall
Scholar ronnywebers
thanks @anusheel but that doesn't solve the problem. Tried with 2010, 2012, ... no success, same error.
Observer bach.long
msvcp110.dll
msvcr110.dll
vccorlib110.dll
to
Hope this helps.
Hi @bach.long,
Glad to know that your issue is resolved, and thanks for providing the solution. Please mark your reply as solution so that it can help other users too.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
Scholar ronnywebers
verified - this worked for me, thanks a lot!
I followed the instructions on Windows 10 64 Bit.
After reinstalling VC++ 2010 and moving the dlls to the folder, the error message changed- now it states:
Application could not be started (0xc000007b).
Any ideas?
MW.
In this case, you might need to reset the settings file. See if that helps.
Rajesh
Newbie rhulsmans1
This is what solved the problem in my case (Vivado 2015.3 on Win7 64 bit):
I copied msvcp110.dll, msvcr110.dll and vccorlib110.dll from C:\Xilinx\.xinstall\Vivado_2015.3\bin to C:\Xilinx\.xinstall\Vivado_2015.3, and ran the uninstaller again successfully.
Hope this helps.
Cheers,
Roger
Hi @rhulsmans1,
Thanks for sharing the solution. It will be helpful for other users facing the same issue.
Nupur
The solution from rhulsmans1 worked for me as well.  Thanks!
jamieson
