Scholar ronnywebers
Vivado 2018.2 installation on linux - am I supposed to install as sudo?
I'm installling Vivado 2018.2 on a VM running Ubuntu 16.04.3 LTS (64-bit).
When I just launch ./xsetup as regular user, I get stuck in the installer at the point where the installer wants to create the /opt/Xilinx folder:
I know a workaround is this, but I'm still wondering if it's actually better to install Vivado as sudo ...? UG973 gives no details/advise on this.
Community Manager
Community Manager
Re: Vivado 2018.2 installation on linux - am I supposed to install as sudo?
Hi @ronnywebers,
Root permissions is only required for the cable drivers installation. Otherwise you can proceed as Sudo with that work around using the opt/xilinx if that directory has been created.
https://www.xilinx.com/support/answers/62240.html
Thank you,
Devin
Community Manager
Community Manager
Hi @ronnywebers,
Thank you,
Devin
Hello @ronnywebers,
Were you able to overcome this issue? If not, please let us know and we'll be glad to help you further then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
