Vivado 2019.2 Unified installer high CPU/RAM load on Windows
Strange behaviour of installer:
Hello again @leonid_galperin ,
It looks like you may have Max CPU Bandwith selected in the Preferences section of the installation? And this then explain why you are seeing this behaviour.
Can you confirm on this please? Thanks
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @leonid_galperin ,
Were you able at the end to download and install Vivado 2019.2 via Webinstaller? Or is it hanging for you and the installation can't be performed at the end? Can you confirm on this please? Thanks.
Kind Regards,
Anatoli Curran,
Yes, installation works fine and installs all I need, but it eats all PC resource. This is especially strange for download phase - there is nothing to hold in RAM during download process
Kind Regards,
Anatoli Curran,
Wow!
Haven't seen this window. Yes, I'm pretty sure this setting will help.
Thanks for the tip
Linux, same problem, this setting set to "Minimum" did not help.
Xilinx_Unified_2019.2_1106_2127_Lin64.bin
