Vivado HLx 2015.4 Installation User Authentication Loop
Hey all,
I am trying to install Vivado HLx 2015.4 WebPack. I am connected to the internet and I can get through the first couple pages of the installer; however, when the files are supposed to begin downloading, the installer just keeps asking for user authentication. I entered my correct login information, the installer verifies the credientals, but then immediately pops up the same dialog and has me enter them again.
Anyone else experiencing this?
Joe
Re: Vivado HLx 2015.4 Installation User Authentication Loop
So I just found the solution to this problem:
Turns out if the date and time is incorrect on your system, this user authentication loop happens. To clarify, I was able to download the web installer from the Xilinx website, the authentication loop was occuring in the installer itself. After resetting the date and time settings on my system, the installer was able to download the required files and complete the installation.
Best,
Joe
Hi @joekleespies
Try using other browsers. Also delete the browser cache & try using the links given in the following AR.
http://www.xilinx.com/support/answers/65995.html
Thanks,Vijay
Best,
Joe
Hello @joekleespies
Share the xinstall log file here.
If you are using windows OS, it is located at C:\Users\<username>\.Xilinx\xinstall directory
If you are using linux OS, it is located at /home/<username>/.Xilinx/xinstall directory
Vinay
vuppala,
Here is the last part of a failed install log:
2016-01-18 13:54:27,896 DEBUG: b.c:? - Authentication finally, close http client
2016-01-18 13:54:27,933 DEBUG: com.xilinx.installer.gui.x:? - testUserLoginWithNewSetting got login results
2016-01-18 13:54:27,939 DEBUG: p.f:? - The download directory is set in InstRecord.dat: C:\Xilinx\Downloads\Vivado_HL_WebPACK_2015.4\payload
2016-01-18 13:54:27,939 DEBUG: com.xilinx.installer.api.e:? - Set the payload location to C:\Xilinx\Downloads\Vivado_HL_WebPACK_2015.4\payload
2016-01-18 13:54:27,939 DEBUG: p.f:? - Download archive numbers: 102
2016-01-18 13:54:27,940 DEBUG: k.t:? - Authentication error: cookie expired. Invalid User ID or Password.
2016-01-18 13:54:27,940 WARN : p.f:? - There was an error validating user credentials:Invalid User ID or Password..
2016-01-18 13:54:27,940 WARN : p.f:? - The session has expired. Please login again.
2016-01-18 13:54:30,830 ERROR: p.g:? - The session has expired. Please login again.
2016-01-18 13:54:32,768 DEBUG: p.f:? - Canceled.
2016-01-18 13:54:34,073 DEBUG: p.p:? - Need to delete downloaded files: C:\Xilinx\Downloads\Vivado_HL_WebPACK_2015.4
2016-01-18 13:54:34,074 DEBUG: p.f:? - Need to remove xinstall dir: C:\Xilinx\.xinstall\Vivado_2015.4
2016-01-18 13:54:34,074 DEBUG: l.c:? - Deleting REG ENTRIES associated with modules...
2016-01-18 13:54:34,074 DEBUG: p.p:? - Removing files...
2016-01-18 13:54:34,074 DEBUG: p.p:? - Deleting directory C:\Xilinx\Downloads\Vivado_HL_WebPACK_2015.4
2016-01-18 13:54:34,077 DEBUG: p.p:? - Deleting directory C:\Xilinx\.xinstall\Vivado_2015.4
I've highlighted the problem. It looks like the installer registers a cookie for authentication using the server time, but if the system date is set past the expiration of the cookie, then the cookie expires and causes an authentication loop.
Best,
Joe
Newbie yjiang46
i have the same problem, but the time on my system is correct. So what should I do?
Visitor aporozh
Thank you, I had the same issue problem, your trick help me.
Newbie dsaves
Thanks a million.  That is one non-intuitive fix.  Solved my installation login problem.  Thanks!
such a weird issue. thanks for the help! :)
Thank you, bro, I was just getting crazy
Visitor zaidahmad.r
you are an angel, man! wasted my 3 hours just because of this problem.....
