xil3s92f
Vivado/Xilinx SDK Error Incorrect Visual C++ Version
I just installed Vivado using the Web installer. I'm running Windows 8.1 x64. When I try and open either Vivado 2014.1 or Xilinx SDK 2014.1 I get a Visual Studio 2012 Visual C++ Runtime installation window. The Xilinx SDK console says I have the incorrect version. I have tried installing the version located C:\Xilinx\Vivado\2014.1\tps\win64 as well but that just opens up the same window. I have attached the error I get. Does any one know how to fix this?
xil3s92f
I tried the repair option and it didn't change anything. I did find a work around looking at the .bat file. If I just rename xvcredist.exe then it won't run at start up and Vivado opens up. It seems like there is a bug with xvcredist.exe. I do have VIsual Studio 2012 installed which insalled all the Visual C++ Redistributable Packages from 2005-2012. So maybe xvcredist.exe is finding one of the other packages.
vemulad
Run vcredist.exe from C:\Xilinx\Vivado\2014.1\tps\win64. If it prompts you with the same message,
Can you try "repair" it?
Deepika.
Deepika.
xil3s92f
I have now the same issue with Vivado 2014.2. Proviously I have used version 2014.1 and had not prloblem.
Running xvcredist.exe does not help. Any ides to solve this issue?
 I'm using Windows 8.1 x64
Adam
xil3s92f
It works,
Adam
Anonymous
Not applicable
That hack works, but I'd like to know why I have to do that. I install 2014.2 and it ran fine until randomly it would seem, the redistrubtable error started to pop up. Like I said the hack seems to work but why does the error occur?
Also what features might this effect?
lennymbaker
I came across this thread after while installing Vivado 2014.4. I had the 2012 Visual C++ installation popup giving me the option to repair or remove during installation. After reading this thread I ended up renaming the vcredist.exe for both x86 and x64 - that got me through the installation. After that I found that the SDK separately would try to launch the vcredist.exe and renaming it didn't help. I had a newer version of the 2012 redistributable installed already. What ultimately fixed it for me was to make sure I only had the x86 and x64 11.0.61030 version of the 2012 redistributable installed. Then I went to the MS website and found the x86 and x64 redistributable that matched my already installed versions. I ran them each, did a repair, I have not had the popup since and all the Xilinx tools are working without having to rename any vcredist.exe's.
The version that comes with the Xilinx tools is 11.0.60610. The vcredist.exe is in several locations of the Xilinx installation. Renaming didn't help with the SDK because it looks like the SDK itself looks for a proper installation of the 2012 C++ redistributable. At least for 2014.4.
Hope his helps anybody else that comes across this.
Lenny
_______________________
Baker Process & Engineering
http://www.bakerpe.com
canaanav
I am new to Xilinx, and Vivado, but I am no novice to MCU development.  I seem to have issues with everything, this being one of them.  This is an incredibly difficult system to learn.
mvigliar
That was a valid solution if and only if the problem occurred *after* Vivado had been installed properly on my workstation.
I have replicated the error by doing this setup sequence:
1) Vivado 2014.3.1
2) MS Visual Studio 2013 Ultimate (w/ Update 2)
3) MS Visual Studio 2013 Ultimate Update 4
4) Vivado 2014.4
It turned out that this install sequence caused my Vivado 2014.4 xsetup to fail with the same error *during* the VLM launching phase. Then the installer failed to handled the timeout error and hung for more than 1 hour without resuming.
I digged into the batch files in C:\Xilinx\Vivado\2014.4\bin starting from vlm.bat and going backwards, and I found that the error is generated in loader.bat, lines 115-140.
set XVREDIST=%RDI_APPROOT%\tps\%RDI_PLATFORM%\xvcredist.exe
if not [%XIL_PA_NO_REDIST_CHECK%] == [1] (
if exist "%XVREDIST%" (
"%XVREDIST%" -check
if [!ERRORLEVEL!] == [1] (
echo.
echo ERROR: This host does not have the appropriate Microsoft Visual C++
echo redistributable packages installed.
echo.
Then I found this durable solution:
a) Kill the Vivado installer to ensure the xvcredist.exe to be kept on the disk at its path.
b) Manually launching xvcredist.exe, repairing the actual install if any or install it from scratch
c) Uninstall Vivado 2014.4 from Control Panel if present, or manually delete C:\Xilinx\Vivado\2014.4 files (as the installer did not end gracefully, your registry is still not properly setup)
d) Set the environment variable XIL_PA_NO_REDIST_CHECK to value "1". I added it at Computer level, not user.
e) Restart Vivado 2014.4 setup
Now it works as a breeze.
Hope this helps,
Mario
mvigliar
Just tested with Vivado 2015.1. Works as well.
bshajenko
I've had this exact same error appear when I upgraded to the new Vivado 15.1. It appears that the Microsoft Visual C++ 2012 Redistributable (x64) version 11.0.60610 installation fails if you have a newer version of the Visual C++ 2012 Redistributable already installed, i.e., version 11.0.61030. Repair or Uninstall and then Install of 11.0.60610 completes quickly but it still does not work. Uninstalling and reinstalling Vivado 15.1 results in the same error.
The solution that worked for me was:
1. Uninstall Microsoft Visual C++ 2012 Redistrutable (x64) version 11.0.60610.
2. Uninstall Microsoft Visual C++ 2012 Redistrutable (x86) version 11.0.61030.
3. Uninstall Microsoft Visual C++ 2012 Redistrutable (x64) version 11.0.61030.
4. Reboot.
5. Install Microsoft Visual C++ 2012 Redistrutable (x64) version 11.0.60610 from the <xilinx install path>\Vivado\2015.1\tps\win64\xvcredist.exe.
6. Reboot (required after install).
7. Start up Vivado to test it -- now it runs without issues.
8. Exit Vivado.
8. Install Microsoft Visual C++ 2012 Redistrutable (x86) version 11.0.61030 (or latest).
9. Install Microsoft Visual C++ 2012 Redistrutable (x64) version 11.0.61030 (or latest).
10. Start up Vivado to test it again -- it still works.
Basically what was done is all versions of Microsoft Visual C++ 2012 Redistributable were uninstalled. Then the version supplied by Xilinx Vivado 2015 was installed, followed by reinstalling the other (later) versions.
Hope this helps others in the same predicament.
Cheers!
meiser
For me ist worked simply uninstall all Uninstall Microsoft Visual C++ 2012 Redistrutable versions 11.0.61030 It seems no version newer than version 11.0.61010 shoud be installed when installing Vivado 2014.4 Thank you.
stealth07
Do you the exact syntax to set XIL_PA_NO_REDIST_CHECK to value "1 ?
example(would it be something like this):
set XIL_PA_NO_REDIST_CHECK = [1]
cpop
Using Vivado 2015.2 on Win8.1.
What worked for me was installing the latest VCRedist.
1. Uninstall the redist installed by Vivado (go to add remove, sort by date and pick the latest installed VC Redist)
2. Install http://www.microsoft.com/en-us/download/details.aspx?id=30679
oncu
Hey,
I faced the very same issue with Windows 8.1 x64. Easy solution is
*checking the "Programmes and Features" and in the "Installations"
*if there are several "Microsoft Visual C++ 2012 Redistributable (x64)" uninstalling all
*double click to vivado icon
*accepting the installation of "Microsoft Visual C++ 2012 Redistributable (x64)" again
Then it should work.
Bests,
jeffrey.johnson
Voyager
Voyager
oncu's easy solution worked for me with Windows 10 and Vivado 2016.1.
aye
Thanks for posting this! It works on 2014.2 as well.
doniska
That is what changed that ?
hytwgasm
Thanks for posting this ! Really helps a lot !
dm@aggios.com
This problem still occurs even when installing 2016.3 (upgrading from 2015.4) on my Win 8.1 64 laptop. So far I haven't been able to get the proposed solution to work (using the env variable).
Thanks - you're so clever!!- this solved my problem with 2016.4 install.
weiwei2
this solution works for my vivado system edition 2016.2
pmetzgen
I've just encountered this issue in 2017.1 (although previous versions of Vivado installed just fine)
Can fundamental issues like these that are three years old be prioritized in new releases?
renaming worked!! thank you.
baf2099
I too just began to encounter this issue in 2017.1 I've been using it since the day it released without issue and just all of a sudden it won't work. I've tried uninstalling and reinstalling the Microsoft C++ redist packages from Xilinx and Microsoft to no avail. Word to the wise, be very cautious uninstalling your C++ redist packages as other software you have may rely on them, including your anti-virus.
Can someone from Xilinx please comment on this issue and provide some instruction on how we can fix this immediately?
nupurs
@baf2099,
Do you have Microsoft Visual C++ REdistributables 2015 installed?
Nupur
baf2099
Yes, after talking with our FAE, I was told that Xilinx is aware of this issue, and that the official recommendation is to bypass the vcredist check with the environment variable as described in this answer record
https://www.xilinx.com/support/answers/69076.html
tonykaravidas
I've been running 2017.2 for months, and today I started my computer and tried to launch, and it wants to install MVC++ 2015 x64 package. WTH? Why all of a sudden?? And of course it fails as described on this forum post.
vertreko
I had 2018.1 installed then had to install 2017.1 because my customer can't get 2018.1 to work with their license server. Now this redistributable C++ issue has come up, preventing me from using 2017.1.
Xilinx, this is a NIGHTMARE. Please fix your software.
