Vivado webpack install ubuntu 18.04
I tried to install the free webpack, but I am stuck on the terminal message after download:
Can't load 'libInst_7z.dll' (libInst_7z.so: Fehler beim Mappen des Shared Objects)
p7zip package is installed, apt-file can not find this .so file.
I am using Ubuntu 18.04 LTS.
thanks
@kk2434
Ubuntu 18.04 is not supported with Vivado 2018.2.
Can you try installing Vivado on one of the supported OS provided on page 11 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug973-vivado-release-notes-install-license.pdf
Nupur
Thanks, but I can not just switch to another Linux OS.
Maybe I could install the missing files/packages from 16.04...?
Has anyone tried an installation on 18.04?
