Dear Sir
We need Vivado Licence to flash FPGA code to the E310.
Please let us know do we need Vivado Suite System Edition or Design edition?
Many thanks
Re: Vivado
Any idea what does mean by FPGA E310 please?
Many thanks for your support.
Re: Vivado
@ashakil,
Check the table in link below to know the difference:
https://www.xilinx.com/products/design-tools/vivado.html#buy
--Syed
Advisor
Advisor
Re: Vivado
If you are only loading a pre-compiled bitstream onto it (not doing your own design) then you just need Vivado Lab Edition (free, unrestricted).
If you're doing your own design, then you'll probably want Vivado WebPACK (also free), which is largely equivalent to Vivado Design Edition but without support for the larger FPGAs. Since the E310 only uses a Zynq 7020, the lack of support for larger chips does not matter.
Re: Vivado
Re: Vivado
Amazing. Very helpful. Thanks a lot.
