What does "No-Charge IP license type" mean?
In the tools&IP section of VC709 evaluation kit page is mentioned that the packsge is included "10 Gigabit Ethernet PCS/PMA (10GBASE-R)" No-Charge IP license type. what's that mean? Can i generate bitstream with this license type?
I want to implement 10G ethernet. Can i do that with this IP cores license or i have to purchase specific license?
thanks
Re: What does "No-Charge IP license type" mean?
@nariman No Charge License type means this IP is Included at no additional charge with Vivado® software. You can make use of this IP with your vc709 without any additional cost.
-Pratham
-Pratham
