Windows license server - computer name change
I had a Vivado floating license server running properly on a Windows 7 machine. However, our IT department changed the Computer Name of this computer in order to comply with a standard naming convention they have established as a policy for our building. Now my licese server does not start up properly. The log file says this:
14:53:59 (lmgrd) "U7SMITH1234": Not a valid server hostname, exiting.
14:53:59 (lmgrd) Valid license server system hosts are: "W7-Smith"
What do I need to do to get the license server working again?
If necessary, I think I can change this PC back to the old Computer Name temporially.
Also, support for my license recently expired, but according to the email I received "you may continue to use your current product version beyond the license subscription end date indefinitely, you will not have access to new product versions as they become available." So, I don't think that will be an issue
Greg
Re: Windows license server - computer name change
After spending quite a while working on this, I finally have it working. Returning the license and re-activating it did not solve the problem. The answer turned out to be quite simple. Just edit Xilinx_Server..lic (or whatever name you call your file) and change the host name to the new computer name. I wish I had known it was something that simple.
Hi @gregn928,
You can return the licenses and regenerate for new server.
If it is activation based follow the steps mentioned here:
http://www.xilinx.com/support/answers/60525.html
If it is certificate based, follow steps mentioned here:
http://www.xilinx.com/support/answers/36136.html
Nupur
Hello @gregn928
Check this answer record on your query about expiry: http://www.xilinx.com/support/answers/34097.html
Vinay
Hello @gregn928
Glad that the issue was solved.
Please close the thread by marking the correct post as "Accept as Solution"
Vinay
