jp123
Xilinx FlexLM License TCP Port Issues
Update****
When installing a Vivado Flex LM License File on your License Server that hosts multiple License Files, make sure to not input any Port Numbers in the License File. Let the Service pull an open port which you can then set on the Manage Xilinx Licenses application. Hope this information helps.
ansarimo
Hi @jp123 ,
Thanks for sharing the valuable information with other users here on Xilinx forums, it's much appreciated.
I hope this post helps the one struggling with the issue you mentioned.
If you don't need any assistance in relation to this topic then please close this thread by accepting it as a solution.
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
