anoopkrishna
cannot uninstall vivado 2019.2
Hello all, I am running to cosim problems and decided to uninstall the existing 2019.2 version and make a clean install of a newer version. Following one of the suggestions from the community forum, I tried to uninstall from the xilinx information center as shown below
 after a shortwhile, a window is popping up and immediately closing
 I tried uninstalling using control panel as well, it is having the same issue. Tried restaring the Laptop and still the same. has anyone faced similar issues? can someone please help me with this.
ansarimo
Hi @anoopkrishna ,
Please refer to the following User guide for uninstalling Vivado 2019.2:
Uninstalling the Vivado Design Suite: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug973-vivado-release-notes-install-license.pdf#page=45
You can manually delete the Xilinx folder in the C drive. Also, remove any related files from the App data.
C:\Users\athandr\AppData\Roaming\Xilinx
C:\Users\athandr\AppData\Local\Xilinx
Hope this helps.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
anatoli
Hello @anoopkrishna ,
The command to uninstall Vivado is:
<Vivado installation directory>Xilinx/.xinstall/Vivado_2019.2/xuninstall -Uninstall
If there are any folders/files left unremoved by running the command above, please manually remove these.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anoopkrishna
Thank you I will try that
anoopkrishna
anoopkrishna
Hello Ansari,
thank you for the suggestion. I will try that.
I am having an issue with
hello Anatoli,
can you please help me with this?
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Vivado-HLS-cosimulation-of-a-code-running-into-infinite-loop/m-p/1157945
Can you please help me with this?
anatoli
Unfortunately, I am not an expert in this area (Vivado HLS), so can't really help on this issue in the link you've shared. Vivado HLS guys are really the ones who'd be able to support you on this.
Kind Regards,
Anatoli Curran,
Versal Blogs
