tifanaser
cant download ise
it says
Please correct the errors and send your information again.
We cannot fulfill your request as your account has failed export compliance verification.
anatoli
Hello @tifanaser ,
Please check my reply in your other/same topic that you've raised for the same issue: https://forums.xilinx.com/t5/Installation-and-Licensing/Please-correct-the-errors-and-send-your-information-again-We/m-p/1237792/highlight/true#M32584
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Hello @tifanaser ,
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
