design is not upgrading
Hi Folks,
Present design is made in vivado 2015.2.
i updrade the vivado tool to 2016.4 but design is not upgrading from 2015.2 to 2016.4 .
what is the problem here, please any one suggest me.
Thanks and Best regards
Vinod Sajjan
@florentw,
Yes i added that custom ip again.
Now, design is upgraded.
Thanks you
Vinod Sajjan
Hi @vinodsajjan,
What warnings/errors are you seeing in Vivado 2016.4?
Prathik
Helpful answer -> Give Kudos
Hi Prathik,
Thank you for response.
Here i am attaching two screenshot please find the attachment.
Hi @prathikm
Thanks for response.
I am attaching screen shots here. please find the attachment.
Thanks and Best Regards
Vinod Sajjan
Hi @vinodsajjan,
Can you click on Tools> report> report IP status?
Then click on the upgrade IPs in the below IP status tab.
Prathik
Hi @prathikm
Thanks for fast response.
Yes i done that but still same thing is showing.
upgrade selected button is disable.
@vinodsajjan,
Check out Appendix A at page 97 in below user guide:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug896-vivado-ip.pdf
Also the below forum thread:
https://forums.xilinx.com/t5/Design-Entry/IP-definition-not-found-IP-contains-locked-subcore/td-p/747060
--Syed
Hi @vinodsajjan,
You are missing the definition for the IP bottom_pin_hole which is you custom IP.
You should first add the location of this custom IP to the IP repository.
Kind Regards,
Florent
Florent
@florentw,
Thanks you
Vinod Sajjan
