Anonymous
Not applicable
licence invalidation problem.
i have installed ise 14.4 on slackware 12.1, and it worked well seemingly, except planAhead, vivado.
now i changed my pc, because the first one doesn't have gbe card.
then, i have spent a week to reinstall things.  the slackware is ok now, i am sure of it.
then i installed ise again,  refresh licence file, i got these
1, hostid doesn't match.
2, ise navigator nullified.
3. xml parser problem when openning coregen.
tia.
Re: licence invalidation problem.
When you change your PC you need to regenerate the license rehosting with new hostID.
Related article,
http://www.xilinx.com/support/answers/42405.html
Anonymous
Not applicable
modified host id, redownload licence file.
now the match problem is gone.
but the other two problems remain.
coregen gave me a lot of repeated msg.
WARNING:coreutil:948 - Unable to load element
   'xilinx.com:ip:ten_gig_eth_pcs_pma:2.6' from repository.
WARNING:coreutil - XML parser exception in file
   '/home/Xilinx/14.4/ISE_DS/ISE/coregen/repository/spiritconsortium.org/schemas
   /1685-2009/component.xsd', line 63:
   Fatal exception encountered during schema scan
what's that mean? i have reinstalled the whole system.
can't be wrong with my linux system:-P
Please check below thread where similar issue is discussed
http://forums.xilinx.com/t5/DSP-Tools/Integrating-Sysgen-module-under-verilog-top-module/td-p/386725
Ashish
Anonymous
Not applicable
hi Ashish,
some file have been corrupted. don't know what it means.
XML parser exception? which xml parser?
WARNING:coreutil:949 - Unable to load generator chain? i don't know what coreutil is, i mean totally.
i don't think i can do anything about it, except waiting for your help.
i have installed this 7 times, since then.
thank you for your help.
Can you please attach xinfo file here?
To generate xinfo, please run below commands
1. source <ise_install_directory>/14.4/ISE_DS/settings64.sh
2. xinfo
Ashish
It looks like a compatibility problem. Please make sure you are install ISE on the supported OS.
Sean
Are you facing any issue while generating xinfo ?
If yes, feel free to let us know.
Ashish
