license problem with XPS, platgen 14.3
I'm experiencing a license problem with software version 14.3. We purchased an ml605 board and I have the related license xps_tpd node locked to the PC I'm using
When I start the xps an error windows pops up with the error: "A license was not found for XPS feature [...] The Xilinx License Manager (XCLM) wiil be launch[..]
I'm able to select the license file in the "Manage Xilinx licences"  tab in XCLM. The ciolumns  "Host ID matches", "Licence CRC" are both okay for all the rows.
Then the problem occurs  in exporting  a design from xps to sdk. Without success, I tried to follow the suggestions in the forum for this kind of problem. .in particular when xps exporting procedure  invokes:
platgen -p xc6vlx240tff1156-1 -lang vhdl -intstyle default -msg
__xps/ise/xmsgprops.lst visimalogic.mhs
It gives the error:
ERROR:MDT - INFO:Security:71 - If a license for part 'xc6vlx240t' is available,
it will be possible to use 'XPS_TDP' instead of 'XPS'.
INFO:Security:60 - The XILINXD_LICENSE_FILE environment variable is set to
'D:\Xilinx\Xilinx.lic'.
INFO:Security:62 - The LM_LICENSE_FILE environment variable is set to
INFO:Security:68 - For more information or for assistance in obtaining
a license, please run the Xilinx License Configuration Manager
(xlcm or "Manage Xilinx Licenses".)
INFO:Security:68a - user is MB238381, on host GRE043548.
WARNING:Security:9b - No 'XPS' feature version 2012.10 was available for part
'xc6vlx240t'.
ERROR:Security:10 - No 'XPS_TDP' feature version 2012.10 was available for
part 'xc6vlx240t'.
No such feature exists.
Feature: XPS
In the attachment there's the file xinfo.txt
Do you have any suggestions?
Re: license problem with XPS, platgen 14.3
From the following link: http://www.xilinx.com/products/boards-and-kits/EK-V6-ML605-G.htm
it is clear that you had Logic Edition license.
See this link: http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/ise_c_overview.htm
In the above link, it clearly states that logic edition do not include XPS tool.
You need to purchase separate embedded edition license to use XPS, SDK tools with xc6vlx240t device.
I hope it is clear now.
I dont see XPS_TDP/XPS feature listed in the xinfo file.
Do you have a ISE webpack license? If yes, can you try to copy it to C:/.Xilinx and restart ISE.
Check this AR http://www.xilinx.com/support/answers/53751.htm
Deepika.
Deepika.
Thanks for sharing xinfo file. From the xinfo file, I observed that you have webpack license and Logic Edition license.
With Logic edition license, you cannot access the XPS tool.
With Webpack license, you can access XPS by targeting the following devices XC7Z010, XC7Z020 and XC7Z030 only.
One of the issue with webpack license is discussed here: http://www.xilinx.com/support/answers/51895.htm
Sorry I do not understand well the point.
I generated the license nine months ago using the code of the ML6505 Evaluation kit. In the kit instructions and documenttion there are several example that uses XPS. Do I need to add another license to use XPS with the target device xc6vlx240t? Is this situation dependent by the software release? I mean, if I switch to a previous software release ( the 13.4, that was distributed with the kit, as example) will I have the same situation. I understand that my problem is really specific and related to a specific product, so thank you for yours helps!
Yes, thank you!
best regards
Michele
