zhengchaofeng
license was not found for feature 'PartialReconfiguration'
Hello, everyone
I am getting the below error. I think I am using correct license but still getting this error.
ERROR: [Vivado 12-2687] A valid license was not found for feature 'PartialReconfiguration'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ"
I check the License Manager and make sure I have this feature in license.
无标题.pngPS.My vivado version is 2017.4
bandi
Hi @zhengchaofeng,
Can you please run the below command from Vivado TCL console and share the generated xinfo.txt file.
report_environment -file xinfo.txt
Thanks & Regards,
Sravanthi B
bandi
Hi @zhengchaofeng,
Thanks & Regards,
Sravanthi B
zhengchaofeng
