problem whit Manage Xilinx Licences
hi!
i can't load any kind of licence on my computer (either free licence for WebPack or floating licence). when i run Manage Xilinx Licences, occurs one problem. whole sistem freeze.
thanks for your help,
Klemen
Re: problem whit Manage Xilinx Licences
Hi Klemen,
What is the OS you are working up on?
You can directly set XILINXD_LICENSE_FILE environmental variable to the location of license or port_name@server_name in case of floating license.
Check this article for details on how to set env variables http://www.xilinx.com/support/answers/11630.html
Another option is to copy the licenses to <home>/.xilinx location and restart ISE (incase of node locked license).
Deepika.
Deepika.
Try below steps to invoke xlcm:
1. Open ISE Command Prompt (Start --> All Programs --> Xilinx Design Tools --> ISE DEsign Suite 14.x --> Accessories --> ISE Design Suite 32 Bit Command Prompt)
2. Run the command: xlcm
Vinay
hi!
i'm using OS WIN7 and i try both proposal and didn't work. do you think it's posible that i didn't install SW (ISE 14.7) correctly?
thanks both of you
have a nice day,
Klemen
Hi Klemen,
You need to restart ISE after setting environmental variables.
Deepika.
Deepika.
Hi Moving to Installation and Licensing board.
Thanks,Vijay
Hi @klemen89
Is this issue resolved? If yes, please close the thread by marking the post which helped you as answer.
Deepika.
Deepika.
