vivado 2017.2 install failed
hi, all
The vivado 2017.4 can be installed successfully. however, 2017.2 is failed, that is it can't pop-up the "Installation completed successfully" dialog like the below snapshot:
The final installation status which has last for ten hours is as below snapshot:
The installation files on the disk will disappear if I force close the dialog.
How to fix it?
xiaohu125
Re: vivado 2017.2 install failed
This can be solved by shut down the pc at the end of installation process.
