sai1@
vivado Licences
  What is the difference between Certified Based Licence and Activation Based Licence?
  Which is suggestable for B.Tech students for their Laboratory? Why?
Basic Requirements for students: 1. Pre Synthesis simulation 2.Post synthesis simulation 3.Bit file generation 4.FPGA Implementation
So,  Certified Based license is supporting for these requirements. Is it ok for students (or) Not? why
Murthy
anatoli
Hello sai1@,
Please note that the activation based licensing methodology is no longer supported and has been deprecated.
Therefore, you won't be able to obtain any Activation Based Licenses from Xilinx Product Licensing page. Only Certificate Based licenses are available these days.
As you may already know, from Vivado 2016.1 release (and newer), when targeting any Vivado WebPACK supported devices in your design, you are no longer needed to obtain a Vivado WebPACK license for this. It's handled now by the tool to not checkout device license for webpack devices. There is actually no physical license anywhere when you install Vivado 2016.1 and newer releases.
FYI - for any other Vivado releases prior 2016.1, you'd still need to log in to www.xilinx.com/getlicenses and generate Vivado WebPACK license file and install this then on a PC.
Since you are using 2016.2, then all what is needed here is the Vivado WebPACK 2016.2 installation and that is all you'd need in this case.
If you later decide to work with System Generator for example, you'd then need an additional SysGen standalone license file, as SysGen requires a license that is not supported by a WebPACK license file.
I hope the above is clear.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
drjohnsmith
Are you using the web pack ?
sai1@
Yes. Vivado software was installed from xilinx website.
drjohnsmith
which version of vivado ?
there is webpack, hls , hlx et all ( i cant remember all the options )
sai1@
I am using Vivado 2016.2   I obtained licence of  Free Vivado WebPACK, After that Analyzer,HLS,SDK,v_WebPACK tools are activated, These tools are certificate based licenses. Is it for BTech students for fpga implementation labarotary.
anatoli
Hello sai1@,
Kind Regards,
Anatoli Curran,
Versal Blogs
sai1@
Thank you very much. I have another doubt. What is the difference between nodelock licence and floating licence? Once again thanks for ur reply.
Murthy
rshekhaw
Hi sai1@,
Please check this link:
https://www.xilinx.com/support/answers/40131.html
Raj.
drjohnsmith
Node locked, are tied to a computer, so if that computer is not in use, you can not use that licence.
Floating , reside on a computer via a server program on that computer
other computers can then use that licence, so if you have three floating licences, any three connected three computers can run the software.
