johndap
webpack and planahead
Do I need t have already purchased PlanAhead to use it with a Webpack license?  I need to install ISE/PlanAhead 14.1 or newer for some maintenance on an existing Spartan6 design.
I set up a webpack license but I don't see anything about PlanAhead:
# ----- REMOVE LINES ABOVE HERE --------------------------
# This license is valid from Fri Nov 04 00:55:14 UTC 2016.
# This is license NODELOCKED to HOSTID=ANY;
# there is no need to run lmgrd for this license.
# This is a permanent license generated on Fri Nov 04 00:55:14 UTC 2016
INCREMENT SDK xilinxd 2017.11 permanent uncounted 3xxxx1F3BEB4 \
VENDOR_STRING=xxx,SDK,software,permanent,_210566005_0_0_405 \
HOSTID=ANY ISSUER="Xilinx Inc" START=04-Nov-2016 TS_OK
INCREMENT Analyzer xilinxd 2017.11 permanent uncounted Dxxxx48712CB \
VENDOR_STRING=xxx,Analyzer,software,permanent,_210566005_0_0_843 \
INCREMENT HLS xilinxd 2017.11 permanent uncounted 5xxxxF00C68B \
VENDOR_STRING=xxx,HLS,software,permanent,_210566005_0_0_521 \
INCREMENT V_WebPACK xilinxd 2017.11 permanent uncounted CxxxxA9813F3 \
VENDOR_STRING=xxx,V_WebPACK,software,permanent,_210566005_0_0_326 \
# ----- REMOVE LINES BELOW HERE --------------------------
I've seen other posts where people had the same issue but the answer was never documented.  A contractor with PlanAhead did this design originally.  Can I modify it with Webpack?
johndap
That is correct.  For some reason I could not access the ISE Webpack license via the license site so my FAE had to send me a license.  The proper license looks something like this:
# This is a permanent license generated on Tue Nov 08 18:00:56 UTC 2016
INCREMENT ISE_WebPACK xilinxd 2017.11 permanent uncounted \
92xxxx1xxxx8 \
VENDOR_STRING=xxx,ISE_WebPACK,software,permanent,_151388_202xxx033_0_116 \
HOSTID=ANY ISSUER="Xilinx Inc" START=08-Nov-2016 TS_OK
#  The following PACKAGE definition is a REQUIRED part of this license:
PACKAGE ISE_WebPACK xilinxd 2017.11 xxxx2Fxxxx54 COMPONENTS="SDK \
ChipScopePro_SIOTK ChipscopePro WebPACK XC7Z010 XC7Z030 HLS \
xps_tdp XC7Z020 PlanAhead" OPTIONS=SUITE
No, you cannot use this license because the codes have been modified. You need to download the ISE_Webpack license or request a license from your FAE.
vuppala
Hi @johndap
Which device are you targeting?
If you are targeting WebPACK device, then you need an ISE WebPACK (free) license.
Vinay
balkris
Check the license status. This license doesn't have plan ahead. You may need to contact your FAEs
Thanks and Regards
Balkrishan
johndap
@vuppala XC6SLX16-2CSG225 so the software_matrix.pdf says WebPack should support it.
johndap
@balkris - does your license specifically list PlanAhead?
syedz
@johndap,
Can you please share the xinfo report?
To generate xinfo file,
start menu start->Xilinx ISE design suite->Accessories->xinfo system checker.
It will generate xinfo.txt file. Please attach it here
Make sure you are pointing the Licenseing correctly.
Open the XLCM (start --> ISE Design Suite --> Accesories --> Manage Xilinx Licenses). Now enther the path to license file in XILINXD_LICENSE_FILE box (say C:/Xilinx_license/xilinx.ic) and click on set.
Syed
vuppala
Hi @johndap
The license you pasted in your first post doesnt have ISE WebPACK license.
Since you are targeting WebPACK device, you have to generate ISE WebPACK license.
Vinay
johndap
92xxxx1xxxx8 \
