Visitor kelliher
xbinst error
I get the following error and I'm not sure how to resolve it:
No platform was found that matches 'xilinx_vcu1525_dynamic_5_1 License found
The valid platforms supported by the license found are:
Nothing listed
running a vcu1525 board on Ubuntu
Linux Mina 4.15.0-42-generic #45-Ubuntu SMP Thu Nov 15 19:32:57 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Re: xbinst error
Hello @kelliher,
Based on what you have shown, you have actually installed and is using 2018.2 XDF Edition of SDAccel, and this build is only intended for Alveo cards. There is no VCU1525 as part of that install.
****** xbinst v2018.2.xdf (64-bit)
  **** SW Build 2342198 on Tue Sep 25 18:17:42 MDT 2018
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
From the Downloads page, you can read this note:
IMPORTANT:
This release is dedicated to the development of applications for the Alveo cards (U200 and U250).  For other platforms please use the regular 2018.2 release of SDAccel.
i.e.
Therefore, please uninstall 2018.2 XDF edition and install a regular 2018.2 release of SDAccel and this will fix your issue then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Re: xbinst error
Hello @kelliher,
I believe this is in relation to SDAccel, as you have mentioned xbinst in your post? Do you actually have a valid SDSoC license?
Please checked this Answer Record that has a similar error reported and a possible workaround? https://www.xilinx.com/support/answers/70601.html
Hope this helps.
Kind Regards,
Anatoli Curran,
Visitor kelliher
Re: xbinst error
Using the License Manager  -- View License Status
I see SDAccel  as a Permanent Nodelocked  license along with many others
such as XCVU9P and xcvu9p_bitgen.    BUT NO SDSoC   is this the problem???
I looked at AR# 70601 changed an number of script files to chmod 755
I wasn't totally sure what files he was talking about since the only /platform/ directories I found only contained .hpp files.
So I'm still not sure what to try next???
Re: xbinst error
Hello @kelliher,
Can you please share your Xinfo report generated on the machine where you are seeing this licensing issue?
Xinfo.txt can be generated by running the "report_environment –file xinfo.txt" command in Vivado tools TCL console.
Here is the text for a working run:
$ xbinst -f xilinx_vcu1525_dynamic_5_1 -d out2
****** xbinst v2018.2 (64-bit)
  **** SW Build 2258646 on Thu Jun 14 20:02:38 MDT 2018
Attempting to get a license: ap_opencl
Feature available: ap_opencl
INFO: [XBINST 60-895]   Target platform: /vivado/SDx/2018.2/platforms/xilinx_vcu1525_dynamic_5_1/xilinx_vcu1525_dynamic_5_1.xpfm
Do you see "Attempting to get a license: ap_opencl" and then "Feature available: ap_opencl" in your case? Can you please send us a screenshot of what exactly you are seeing at your end?
Kind Regards,
Anatoli Curran,
Visitor kelliher
Re: xbinst error
Here's the xinfo.txt:
| Tool Version : Vivado v.2018.2.xdf (lin64) Build 2342198 Tue Sep 25 18:17:42 MDT 2018
| Date         : Thu Dec  6 04:58:47 2018
| Host         : Mina running 64-bit Ubuntu 16.04.5 LTS
| Command      : report_environment -file /home/kelliher/xinfo.txt
Environment Report
Table of Contents
1. System Information
2. Environment Variables
3. Vivado Preferences
4. Install Information
5. Version of system dlls called by Xilinx software
6. License Information
Host Information
| Hostname                  | Mina                                      |
| Network Interface Card ID | 00e0670b1526                              |
| C: Drive Serial Number    | (not supported on this platform)          |
| FLEXID Dongle ID          | (not supported on this platform)          |
| Platform                  | Ubuntu                                    |
| Operating System          | Ubuntu 16.04.5 LTS                        |
| Processor Vendor          | Intel                                     |
| Processor Detail          | Intel(R) Celeron(R) CPU  J1800  @ 2.41GHz |
| Processor Speed           | 1559.169 MHz                              |
| Processor Count           | 1                                         |
| Physical Core Count       | 2                                         |
| Logical Core Count        | 2                                         |
Available Disk Space
| Volume                          |   Free |  Total |
| /sys                            |    0 B |    0 B |
| /proc                           |    0 B |    0 B |
| /dev                            |   3 GB |   3 GB |
| /dev/pts                        |    0 B |    0 B |
| /run                            | 777 MB | 787 MB |
| /                               | 833 GB | 961 GB |
| /sys/kernel/security            |    0 B |    0 B |
| /dev/shm                        |   3 GB |   3 GB |
| /run/lock                       |   4 MB |   5 MB |
| /sys/fs/cgroup                  |   3 GB |   3 GB |
| /sys/fs/cgroup/systemd          |    0 B |    0 B |
| /sys/fs/pstore                  |    0 B |    0 B |
| /sys/firmware/efi/efivars       |    0 B |    0 B |
| /sys/fs/cgroup/freezer          |    0 B |    0 B |
| /sys/fs/cgroup/cpuset           |    0 B |    0 B |
| /sys/fs/cgroup/memory           |    0 B |    0 B |
| /sys/fs/cgroup/pids             |    0 B |    0 B |
| /sys/fs/cgroup/blkio            |    0 B |    0 B |
| /sys/fs/cgroup/rdma             |    0 B |    0 B |
| /sys/fs/cgroup/perf_event       |    0 B |    0 B |
| /sys/fs/cgroup/devices          |    0 B |    0 B |
| /sys/fs/cgroup/net_cls,net_prio |    0 B |    0 B |
| /sys/fs/cgroup/cpu,cpuacct      |    0 B |    0 B |
| /sys/fs/cgroup/hugetlb          |    0 B |    0 B |
| /sys/kernel/debug               |    0 B |    0 B |
| /dev/hugepages                  |    0 B |    0 B |
| /proc/sys/fs/binfmt_misc        |    0 B |    0 B |
| /dev/mqueue                     |    0 B |    0 B |
| /sys/kernel/config              |    0 B |    0 B |
| /sys/fs/fuse/connections        |    0 B |    0 B |
| /boot/efi                       | 507 MB | 510 MB |
| /run/user/1000                  | 787 MB | 787 MB |
| /run/user/1000/gvfs             |    0 B |    0 B |
| /home/cubie                     |  49 GB | 909 GB |
Host Memory Information
| Memory Type               |  Value |
| Physical Memory           |   7 GB |
| Available Physical Memory | 176 MB |
| Swap File                 | 976 MB |
| Total Virtual             |   8 GB |
| Available Virtual         |   6 GB |
XDG_SESSION_ID=1
XILINX_DSP=
TERM=xterm-256color
SHELL=/bin/bash
SSH_CLIENT=192.168.0.6 48790 22
RDI_TPS_ROOT=/opt/Xilinx/Vivado/2018.2.xdf/tps/lnx64
SYNTH_COMMON=/opt/Xilinx/Vivado/2018.2.xdf/scripts/rt/data
SSH_TTY=/dev/pts/17
RT_TCL_PATH=/opt/Xilinx/Vivado/2018.2.xdf/scripts/rt/base_tcl/tcl
RDI_PREPEND_PATH=/opt/Xilinx/SDK/2018.2.xdf/bin
RDI_OPT_EXT=.o
USER=kelliher
LD_LIBRARY_PATH=/opt/Xilinx/Vivado/2018.2.xdf/lib/lnx64.o/Ubuntu:/opt/Xilinx/Vivado/2018.2.xdf/lib/lnx64.o:/opt/Xilinx/Vivado/2018.2.xdf/tps/lnx64/jre/lib/amd64:/opt/Xilinx/Vivado/2018.2.xdf/tps/lnx64/jre/lib/amd64/server:/opt/Xilinx/SDx/2018.2.xdf/lib/lnx64.o/Ubuntu:/opt/Xilinx/SDx/2018.2.xdf/lib/lnx64.o:/opt/Xilinx/SDx/2018.2.xdf/runtime/lib/x86_64:/opt/Xilinx/Vivado/2018.2.xdf/bin/../lnx64/tools/dot/lib
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
RDI_PATCHROOT=
TCL_LIBRARY=/opt/Xilinx/Vivado/2018.2.xdf/tps/tcl/tcl8.5
RDI_PLATFORM=lnx64
RDI_BUILD=yes
RT_LIBPATH=/opt/Xilinx/Vivado/2018.2.xdf/scripts/rt/data
RDI_LIBDIR=/opt/Xilinx/Vivado/2018.2.xdf/lib/lnx64.o/Ubuntu:/opt/Xilinx/Vivado/2018.2.xdf/lib/lnx64.o
MAIL=/var/mail/kelliher
PATH=/opt/Xilinx/Vivado/2018.2.xdf/bin:/opt/Xilinx/Vivado/2018.2.xdf/tps/lnx64/jre/bin:/opt/Xilinx/SDK/2018.2.xdf/bin:/opt/Xilinx/DocNav:/opt/Xilinx/SDK/2018.2.xdf/gnu/microblaze/lin/bin:/opt/Xilinx/SDK/2018.2.xdf/gnu/arm/lin/bin:/opt/Xilinx/SDK/2018.2.xdf/gnu/microblaze/linux_toolchain/lin64_be/bin:/opt/Xilinx/SDK/2018.2.xdf/gnu/microblaze/linux_toolchain/lin64_le/bin:/opt/Xilinx/SDK/2018.2.xdf/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/opt/Xilinx/SDK/2018.2.xdf/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/opt/Xilinx/SDK/2018.2.xdf/gnu/aarch64/lin/aarch64-linux/bin:/opt/Xilinx/SDK/2018.2.xdf/gnu/aarch64/lin/aarch64-none/bin:/opt/Xilinx/SDK/2018.2.xdf/gnu/armr5/lin/gcc-arm-none-eabi/bin:/opt/Xilinx/SDK/2018.2.xdf/tps/lnx64/cmake-3.3.2/bin:/opt/Xilinx/SDx/2018.2.xdf/bin:/opt/Xilinx/Vivado/2018.2.xdf/lnx64/tools/bin:/home/kelliher/bin:/home/kelliher/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
QT_QPA_PLATFORMTHEME=appmenu-qt5
PWD=/opt/dsa/xilinx_vcu1525_dynamic_5_1
XIL_CHECK_TCL_DEBUG=False
XILINX_VIVADO_HLS=/opt/Xilinx/Vivado/2018.2.xdf
LANG=en_US.UTF-8
HDI_APPROOT=/opt/Xilinx/Vivado/2018.2.xdf
XILINX_VIVADO=/opt/Xilinx/Vivado/2018.2.xdf
XILINX_SDK=/opt/Xilinx/SDK/2018.2.xdf
ISL_IOSTREAMS_RSA=/opt/Xilinx/Vivado/2018.2.xdf/tps/isl
SHLVL=3
HOME=/home/kelliher
RDI_BASEROOT=/opt/Xilinx/Vivado
RDI_APPROOT=/opt/Xilinx/Vivado/2018.2.xdf
LOGNAME=kelliher
RDI_JAVA_PLATFORM=amd64
XDG_DATA_DIRS=/usr/local/share:/usr/share:/var/lib/snapd/desktop
SSH_CONNECTION=192.168.0.6 48790 192.168.0.20 22
RDI_BINROOT=/opt/Xilinx/Vivado/2018.2.xdf/bin
LESSOPEN=| /usr/bin/lesspipe %s
XILINX_SDX=/opt/Xilinx/SDx/2018.2.xdf
RDI_PROG=/opt/Xilinx/Vivado/2018.2.xdf/bin/unwrapped/lnx64.o/vivado
XDG_RUNTIME_DIR=/run/user/1000
DISPLAY=localhost:10.0
XILINX_PLANAHEAD=/opt/Xilinx/Vivado/2018.2.xdf
HDIPRELDPATH=/opt/Xilinx/SDx/2018.2.xdf/lib/lnx64.o/Ubuntu:/opt/Xilinx/SDx/2018.2.xdf/lib/lnx64.o:/opt/Xilinx/SDx/2018.2.xdf/runtime/lib/x86_64:/opt/Xilinx/Vivado/2018.2.xdf/bin/../lnx64/tools/dot/lib
LESSCLOSE=/usr/bin/lesspipe %s %s
RDI_INSTALLVER=2018.2.xdf
RDI_DATADIR=/opt/Xilinx/Vivado/2018.2.xdf/data
RDI_INSTALLROOT=/opt/Xilinx
_=/opt/Xilinx/Vivado/2018.2.xdf/bin/unwrapped/lnx64.o/vivado
GLIBCPP_FORCE_NEW=1
GLIBCXX_FORCE_NEW=1
HRT_TCL_PATH=/opt/Xilinx/Vivado/2018.2.xdf/scripts/rt/fpga_tcl
RT_INTERUPT=/home/kelliher/.oasys/realTime-interrupt.tcl
NLSPATH=/usr/dt/lib/nls/msg/%L/%N.cat
XFILESEARCHPATH=/usr/dt/app-defaults/%L/Dt
No install information found.
License Information
| Feature                      | S/W or IP Core    | Version | Expiring  | Start Date  | Floating or Node Locked | Count     | ServerName | Host Id      | Host Id Matches | Notice | Issuer                       | Feature Index | License Validity | Licenses in Use | File Name                                                          | Info        |
| Analyzer                     | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 1             | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,board_vivado_design_edition,software,permanent,_211645669_1777540512_210695386_643 |
| Analyzer                     | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 2             | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,SDAccel,software,permanent,_211645669_1777540512_210695386_320                     |
| HLS                          | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 3             | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,board_vivado_design_edition,software,permanent,_211645669_1777540512_210695386_643 |
| HLS                          | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 4             | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,SDAccel,software,permanent,_211645669_1777540512_210695386_320                     |
| Implementation               | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 5             | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,SDAccel,software,permanent,_211645669_1777540512_210695386_320                     |
| PartialReconfiguration       | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 6             | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,board_vivado_design_edition,software,permanent,_211645669_1777540512_210695386_643 |
| PartialReconfiguration       | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 7             | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,SDAccel,software,permanent,_211645669_1777540512_210695386_320                     |
| SDAccel                      | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 8             | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,SDAccel,software,permanent,_211645669_1777540512_210695386_320                     |
| SDK                          | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 9             | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,board_vivado_design_edition,software,permanent,_211645669_1777540512_210695386_643 |
| Simulation                   | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 10            | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,board_vivado_design_edition,software,permanent,_211645669_1777540512_210695386_643 |
| Simulation                   | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 11            | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,SDAccel,software,permanent,_211645669_1777540512_210695386_320                     |
| Synthesis                    | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 12            | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,SDAccel,software,permanent,_211645669_1777540512_210695386_320                     |
| XCVU9P                       | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 13            | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,XCVU9P,software,permanent,_211645669_1777540512_210695386_805                      |
| ap_opencl                    | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 14            | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,SDAccel,software,permanent,_211645669_1777540512_210695386_320                     |
| board_vivado_design_edition  | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 15            | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,board_vivado_design_edition,software,permanent,_211645669_1777540512_210695386_643 |
| xcvu9p_bitgen                | Tools             | 2019.12 | Permanent | 03-Dec-2018 | Nodelocked              | Uncounted |            | 00e0670b1526 | Yes             |        | Xilinx Inc                   | 16            | Okay             | Not Applicable  | /home/kelliher/.Xilinx/Xilinx.lic                                  | kelliher,xcvu9p_bitgen,software,permanent,_211645669_1777540512_210695386_060               |
| axi_usb2_device              | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 17            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,axi_usb2_device,ip,permanent,_0_0_0                       |
| can                          | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 18            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,can,ip,permanent,_0_0_0                                   |
| canfd                        | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 19            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,canfd,ip,permanent,_0_0_0                                 |
| cmac                         | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 20            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,cmac,ip,permanent,_0_0_0                                  |
| cmac_an_lt                   | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 21            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,cmac_an_lt,ip,permanent,_0_0_0                            |
| cmac_usplus                  | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 22            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,cmac_usplus,ip,permanent,_0_0_0                           |
| cpri                         | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 23            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,cpri,ip,permanent,_0_0_0                                  |
| displayport                  | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 24            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,displayport,ip,permanent,_0_0_0                           |
| eth_avb_endpoint             | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 25            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,eth_avb_endpoint,ip,permanent,_0_0_0                      |
| interlaken                   | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 26            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,interlaken,ip,permanent,_0_0_0                            |
| jesd204                      | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 27            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,jesd204,ip,permanent,_0_0_0                               |
| l_eth_basekr                 | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 28            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,l_eth_basekr,ip,permanent,_0_0_0                          |
| l_eth_baser                  | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 29            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,l_eth_baser,ip,permanent,_0_0_0                           |
| l_eth_mac_pcs                | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 30            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,l_eth_mac_pcs,ip,permanent,_0_0_0                         |
| pci32                        | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 31            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,pci32,ip,permanent,_0_0_0                                 |
| pci64                        | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 32            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,pci64,ip,permanent,_0_0_0                                 |
| spdif                        | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 33            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,spdif,ip,permanent,_0_0_0                                 |
| srio_phylog_io               | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 34            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,srio_phylog_io,ip,permanent,_0_0_0                        |
| ten_gig_eth_mac              | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 35            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,ten_gig_eth_mac,ip,permanent,_0_0_0                       |
| ten_gig_eth_pcs_pma_basekr   | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 36            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,ten_gig_eth_pcs_pma_basekr,ip,permanent,_0_0_0            |
| tri_mode_eth_mac             | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 37            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,tri_mode_eth_mac,ip,permanent,_0_0_0                      |
| tsn_bridged_endpoint_eth_mac | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 38            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,tsn_bridged_endpoint_eth_mac,ip,permanent,_0_0_0          |
| tsn_endpoint_eth_mac         | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 39            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,tsn_endpoint_eth_mac,ip,permanent,_0_0_0                  |
| usxgmii_mac_pcs              | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 40            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,usxgmii_mac_pcs,ip,permanent,_0_0_0                       |
| v_ccm                        | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 41            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,v_ccm,ip,permanent,_0_0_0                                 |
| v_cresample                  | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 42            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,v_cresample,ip,permanent,_0_0_0                           |
| v_deinterlacer               | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 43            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,v_deinterlacer,ip,permanent,_0_0_0                        |
| v_enhance                    | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 44            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,v_enhance,ip,permanent,_0_0_0                             |
| v_gamma                      | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 45            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,v_gamma,ip,permanent,_0_0_0                               |
| v_hdmi                       | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 46            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,v_hdmi,ip,permanent,_0_0_0                                |
| v_osd                        | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 47            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,v_osd,ip,permanent,_0_0_0                                 |
| v_rgb2ycrcb                  | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 48            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,v_rgb2ycrcb,ip,permanent,_0_0_0                           |
| v_ycrcb2rgb                  | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 49            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,v_ycrcb2rgb,ip,permanent,_0_0_0                           |
| x_eth_mac                    | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 50            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,x_eth_mac,ip,permanent,_0_0_0                             |
| xxv_eth_basekr               | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 51            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,xxv_eth_basekr,ip,permanent,_0_0_0                        |
| xxv_eth_mac_pcs              | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 52            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,xxv_eth_mac_pcs,ip,permanent,_0_0_0                       |
| xxv_tsn_802d1cm              | IP:Design_Linking | 2018.06 | Permanent | 24-Sep-2018 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 53            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/Xilinx.lic     | License_Type:Design_Linking;ipman,xxv_tsn_802d1cm,ip,permanent,_0_0_0                       |
| PCIE_BLK_PLUS                | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 54            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,PCIE_BLK_PLUS,ip,permanent,_ANY                     |
| PCIE_BLK_PLUS_classic        | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 55            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| RGB2YCRCB                    | IP:Bought         | 2013.10 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 56            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,RGB2YCRCB,ip,permanent,_ANY                         |
| RGB2YCRCB_classic            | IP:Bought         | 2013.10 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 57            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| S6_PCIE                      | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 58            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,S6_PCIE,ip,permanent,_ANY                           |
| S6_PCIE_classic              | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 59            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| TC                           | IP:Bought         | 2013.10 | Permanent | 24-Sep-2013 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 60            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,TC,ip,permanent,_ANY                                |
| TC_classic                   | IP:Bought         | 2013.10 | Permanent | 24-Sep-2013 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 61            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| V4_EMAC                      | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 62            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,V4_EMAC,ip,permanent,_ANY                           |
| V4_EMAC_classic              | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 63            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| V5_EMAC                      | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 64            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,V5_EMAC,ip,permanent,_ANY                           |
| V5_EMAC_classic              | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 65            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| V6_EMAC                      | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 66            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,V6_EMAC,ip,permanent,_ANY                           |
| V6_EMAC_classic              | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 67            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| V6_PCIE                      | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 68            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,V6_PCIE,ip,permanent,_ANY                           |
| V6_PCIE_classic              | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 69            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| XAUI                         | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 70            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,XAUI,ip,permanent,_ANY                              |
| XAUI_classic                 | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 71            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| YCRCB2RGB                    | IP:Bought         | 2013.10 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 72            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,YCRCB2RGB,ip,permanent,_ANY                         |
| YCRCB2RGB_classic            | IP:Bought         | 2013.10 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 73            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| pcie_blk_plus_v1             | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 74            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| s6_pcie_v1                   | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 75            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| ten_gig_eth_pcs_pma          | IP:Bought         | 2012.04 | Permanent | 21-Mar-2012 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc                   | 76            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;ipman,ten_gig_eth_pcs_pma,ip,permanent,_0_0_0                           |
| v4_emac_v4                   | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 77            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| v5_emac_v1                   | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 78            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| v6_emac_v1                   | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 79            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| v6_pcie_v1                   | IP:Bought         | 2010.08 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 80            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| v_rgb2ycrcb                  | IP:Bought         | 2013.10 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 81            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,RGB2YCRCB,ip,permanent,_ANY                         |
| v_rgb2ycrcb_v2               | IP:Bought         | 2013.10 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 82            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| v_tc                         | IP:Bought         | 2013.10 | Permanent | 24-Sep-2013 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 83            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,TC,ip,permanent,_ANY                                |
| v_tc_v1                      | IP:Bought         | 2013.10 | Permanent | 24-Sep-2013 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 84            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| v_ycrcb2rgb                  | IP:Bought         | 2013.10 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 85            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,YCRCB2RGB,ip,permanent,_ANY                         |
| v_ycrcb2rgb_v2               | IP:Bought         | 2013.10 | Permanent | 9-Aug-2009  | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 86            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| xaui_v3_0                    | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 87            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| xaui_v4_0                    | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 88            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| xaui_v5_0                    | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 89            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| xaui_v6                      | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 90            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| xaui_v7                      | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 91            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
| xaui_v8                      | IP:Bought         | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked              | Uncounted |            | ANY          | Yes             |        | Xilinx Inc, ip_license_admin | 92            | Okay             | Not Applicable  | /opt/Xilinx/Vivado/2018.2.xdf/data/ip/core_licenses/XilinxFree.lic | License_Type:Bought        |
***** HERE'S What I get with xbinst  ******
xbinst --platform xilinx_vcu1525_dynamic_5_1 -d /opt/dsa/xilinx_vcu1525_dynamic_5_1
WARNING: [Common 17-259] Unknown Tcl command 'xbinst --platform xilinx_vcu1525_dynamic_5_1 -d /opt/dsa/xilinx_vcu1525_dynamic_5_1' sending command to the OS shell for execution. It is recommended to use 'exec' to send the command to the OS shell.
Platform repo paths:
PlatformMgr contains the following platforms:
ERROR: [XBINST 60-705] No platform was found that matches 'xilinx_vcu1525_dynamic_5_1'. Make sure that the platform is specified correctly and that valid license is installed. The valid platforms supported by the license found are:
ERROR: [XBINST 60-587] Failed to add a platform: specified platform xilinx_vcu1525_dynamic_5_1 is not found
child process exited abnormally
Re: xbinst error
Hello @kelliher,
IMPORTANT:
i.e.
Kind Regards,
Anatoli Curran,
Visitor kelliher
Re: xbinst error
Thanks,  would never have noticed that.    Works fine now.
