Participant pedro_machado
Error creating a custom DPU project
I am building a custom DPU for our boards https://github.com/SundanceMultiprocessorTechnology/VCS-1 and I am not able to complete the following steps in Step 5: Configure the rootfs
Apps ->
autostart
Reason: Option Not available
Modules ->
  • dpu
User Packages ->
  • dnndk
Please note that I completed all the steps before without any problem.
Issue report also here .
Re: Error creating a custom DPU project
I think that it is petalinux-image-full.bbappend not petalinux-image.bbappend that describes IMAGE_INSTALL_append in 2018.3.
Refer to Note.2.
Requirements for Using the Xilinx DPU
This section lists the software and hardware tools required to use the Xilinx® Deep Learning Processor (DPU) IP to accelerate machine learning algorithms.
Software Requirements
  • Vivado® Design Suite 2018.2
  • Board files for Ultra96 v1 should be installed
  • Xilinx SDK 2018.2
  • PetaLinux 2018.2
Note: This tutorial is known to work with Vivado/Petalinux/SDK v2018.3, but 2018.2 will provide a better experience at this time. To use it with 2018.3, you will need to make the following changes:
  1. Edit the u96_dpuv2.0_2018.2.tcl script to specify 2018.3.
  2. Change the petalinux-image.bbappend to petalinux-image-full.bbappend.
You need to add the recipes for these items. While following the instruction in https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/DPU-Integration we add recipes in below step,
Step 2: Copy recipes to the PetaLinux project
After copying these files, the options will be shown in rootfs.... You need to do the same for your custome design.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
I think you're probbly missing this step:
vi project-spec/meta-user/recipes-core/images/petalinux-image.bbappend
Add the following lines:
IMAGE_INSTALL_append = " dnndk"
IMAGE_INSTALL_append = " autostart"
IMAGE_INSTALL_append = " dpu"
Hi @meherp and @terryo
Many thanks for you suggestions but I am afraid that I am stuck in the same place. As I said, initially, I completed all those steps. Check bellow the output of tree, cat for each one of the recipies and screenshoots of the rootfs_config:
ZU4EV_dpu$ tree project-spec/meta-user/recipes-apps/
├── autostart
│   ├── autostart.bb
│   └── files
│       ├── autostart.sh
│       └── trd-autostart.sh
├── dnndk
│   ├── dnndk.bb
│   ├── files
│   │   ├── bin
│   │   │   ├── dexplorer
│   │   │   └── dsight
│   │   ├── include
│   │   │   ├── dnndk.h
│   │   │   ├── dputils.h
│   │   │   └── n2cube.h
│   │   └── lib
│   │       ├── echarts.js
│   │       ├── libdputils.so.3.1
│   │       ├── libdputils.so.3.3
│   │       ├── libdsight.a
│   │       ├── libhineon.so
│   │       └── libn2cube.so
│   └── README
├── gpio-demo
│   ├── files
│   │   ├── gpio-demo.c
│   │   └── Makefile
│   └── gpio-demo.bb
└── peekpoke
    ├── files
    │   ├── Makefile
    │   ├── peek.c
    │   └── poke.c
    └── peekpoke.bb
11 directories, 23 files
├── conf
│   ├── layer.conf
│   └── petalinuxbsp.conf
├── COPYING.MIT
├── README
├── recipes-apps
│   ├── autostart
│   │   ├── autostart.bb
│   │   └── files
│   │       ├── autostart.sh
│   │       └── trd-autostart.sh
│   ├── dnndk
│   │   ├── dnndk.bb
│   │   ├── files
│   │   │   ├── bin
│   │   │   │   ├── dexplorer
│   │   │   │   └── dsight
│   │   │   ├── include
│   │   │   │   ├── dnndk.h
│   │   │   │   ├── dputils.h
│   │   │   │   └── n2cube.h
│   │   │   └── lib
│   │   │       ├── echarts.js
│   │   │       ├── libdputils.so.3.1
│   │   │       ├── libdputils.so.3.3
│   │   │       ├── libdsight.a
│   │   │       ├── libhineon.so
│   │   │       └── libn2cube.so
│   │   └── README
│   ├── gpio-demo
│   │   ├── files
│   │   │   ├── gpio-demo.c
│   │   │   └── Makefile
│   │   └── gpio-demo.bb
│   └── peekpoke
│       ├── files
│       │   ├── Makefile
│       │   ├── peek.c
│       │   └── poke.c
│       └── peekpoke.bb
├── recipes-bsp
│   ├── device-tree
│   │   ├── device-tree.bbappend
│   │   └── files
│   │       ├── multi-arch
│   │       │   ├── zynqmp-qemu-multiarch-arm.dts
│   │       │   └── zynqmp-qemu-multiarch-pmu.dts
│   │       ├── system-user.dtsi
│   │       └── zynqmp-qemu-arm.dts
│   └── u-boot
│       ├── files
│       │   └── platform-top.h
│       └── u-boot-xlnx_%.bbappend
├── recipes-core
│   ├── base-files
│   │   └── base-files_%.bbappend
│   └── images
│       ├── petalinux-image.bbappend
│       └── petalinux-image-full.bbappend
└── recipes-modules
    └── dpu
        ├── dpu.bb
        ├── files
        │   ├── COPYING
        │   ├── dpucore.c
        │   ├── dpucore.h
        │   ├── dpudef.h
        │   ├── dpuext.c
        │   ├── dpuext.h
        │   └── Makefile
        └── README
25 directories, 46 files
├── autostart
│   ├── autostart.bb
│   └── files
│       ├── autostart.sh
├── dnndk
│   ├── dnndk.bb
│   ├── files
│   │   ├── bin
│   │   │   ├── dexplorer
│   │   │   └── dsight
│   │   ├── include
│   │   │   ├── dnndk.h
│   │   │   ├── dputils.h
│   │   │   └── n2cube.h
│   │   └── lib
│   │       ├── echarts.js
│   │       ├── libdsight.a
│   └── README
├── gpio-demo
│   ├── files
│   │   ├── gpio-demo.c
│   │   └── Makefile
│   └── gpio-demo.bb
└── peekpoke
    ├── files
    │   ├── Makefile
    │   ├── peek.c
    │   └── poke.c
    └── peekpoke.bb
$ tree project-spec/meta-user/recipes-core/
├── base-files
└── images
2 directories, 3 files
ZU4EV_dpu$ cat project-spec/meta-user/recipes-core/images/petalinux-image.bbappend
Screenshot from 2019-10-12 18-31-37.pngScreenshot from 2019-10-12 18-31-18.pngScreenshot from 2019-10-12 18-29-24.pngScreenshot from 2019-10-12 18-28-34.png
Refer to Note.2.
  • Xilinx SDK 2018.2
  • PetaLinux 2018.2
Many thanks. It worked.
