Observer overing1314
Open Camera Error for ZedBoard
I downloaded xilinx_dnndk_v3.1 and successfully installed the zedbaord DPU.
I followed the description to test the face_detection but keep come out with Open Camera Error.
1. I changed the ip address followed the host computer and run the make file. (The file has built successful)
2. Run eth-show/eth_show.exe on the host computer (There are nothing display on terminal)
3. The "Open Camera Error" come out.
I already forwarded the X11 and I can run the resnet50, but face_detection cannot. Please help me Thanks...
回复: Open Camera Error for ZedBoard
Hi Overing 1314,
Have you fixed this issue? I have exactly the opposite problem. The face-detect works using the eth_show. exe on my Win10 laptop, but I cannot get X11 to run on my Linux laptop.
When I try to run ssh -X or any other X11 cammnds I get -sh xauth : command not found.
How did you get X11 working on the ZedBoard with the DNNDK demo working?
Also, the Resnet50 demo runs, and I get text output to the console, but it will not put video to the eth_show and refuses to connect via X11
DJE666
Hi @overing1314 ,
It seems that you are failed to open the default USB camera.
I would suggest you to check if the camera device is available.
Like using the following command:
root@zcu102_dpu_test:~# cat /sys/class/video4linux/video0/name
USB 2.0 Camera: USB Camera
Best Regards,
Jason
is it any problem when I plugged ny usb webcame to usb port it shows this on terminal:
usb 1-1: new high-speed USB device number 3 using ci_hdrc
Hi @overing1314 ,
You should get more information like the one I got on ZCU102:
[   49.565544] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[   49.807904] usb 1-1: New USB device found, idVendor=0c45, idProduct=6366, bcdDevice= 1.00
[   49.816082] usb 1-1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[   49.823216] usb 1-1: Product: USB 2.0 Camera
[   49.827483] usb 1-1: Manufacturer: Sonix Technology Co., Ltd.
[   49.833221] usb 1-1: SerialNumber: SN0001
[   49.845974] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (0c45:6366)
[   49.876339] uvcvideo 1-1:1.0: Entity type for entity Extension 4 was not initialized!
[   49.884177] uvcvideo 1-1:1.0: Entity type for entity Extension 3 was not initialized!
[   49.892004] uvcvideo 1-1:1.0: Entity type for entity Processing 2 was not initialized!
[   49.899916] uvcvideo 1-1:1.0: Entity type for entity Camera 1 was not initialized!
[   49.907657] input: USB 2.0 Camera: USB Camera as /devices/platform/amba/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.0/input/input1
If you can't find the video device for USB cam I would suggest you to check if the cam is working properly.
I have done some quick research on internet and find a post of debugging usb cam on Zedboard like below:
http://www.zedboard.org/content/intefacing-usb-webcam-zedboard-running-petalinux
Best Regards,
Jason
Hi @overing1314 ,
Have you resolved your new problem here since you marked your new question as sollution?
If not I would suggest you to create a new post for this new question and keep the text version of your error message in the post so that anyone else can search with your error message.
Best Regards,
Jason
Hi Overing 1314,
DJE666
Observer zxbzsb
Re: Open Camera Error for ZedBoard
How did you install the zedboard DPU, and would you like to share the tutorial?
Hi @zxbzsb ,
You may check this post:
https://forums.xilinx.com/t5/Machine-Learning/ERROR-quot-DNNDK-Failure-of-DPU-memory-space-used-out-quot-when/td-p/1038594
Best Regards,
Jason
