Visitor buivanthang
decent_q failed
I tried to run decent_q for MNIST'model (which I had created. I followed this guide) I grabed a trouble when try to input calibation data as figure following: I used DNNDK3.1
So I need your help!!!!!! thanks
Re: decent_q failed
Perhaps your image didnt load correctly. Check your path and try to print name of image
Re: decent_q failed
Visitor buivanthang
Re: decent_q failed
Thanks bro, I had solved it.
