lei1
AXI-4 addressing (read command)
Hello everone,
I created a DDR3-Interface using the MIG-IP connected via AXI with an interconnect. I designed an own control-master-module. Therefor I used the "create and package IP" tool and modiefied the axi-code for my own purpose. So far, so good.
Writing is working properly.
When I try to readout the written bytes, the axi-araddress is set to a value and handed over to the mig-module. The correct address can be monitored through the different modules. At the end the correct address reaches the mig-module.
But, the read-data, that returns is not what I would expect.
It seems as if the last two bits of the read-address (araddr) are not interpreted at all. Example: If I set the address to "0000 1011" the readout begins with byte no. 2.
I checked all connections, they are correct. Is there something I don't see?
Thanks in advance!
Lei
vsrunga
@lei1,
I think your observation is correct.
Please look into AXI Addressing mapping section of UG586 for more details
http://www.xilinx.com/support/documentation/ip_documentation/mig_7series/v2_4/ug586_7Series_MIS.pdf
Based on UI, Memory data width and nck_per_clock ratio AXI Byte address lower bits will get masked.
Black boxes shoes possible cases of 2 bit masking.
Hope this helps,
Vanitha
muzaffer
How do you know if writing is working properly? Maybe you are not writing the correct data at the right address. What do you set for strobes when you write?
Also what data do you write to what address and what do you read. Start with some simple aligned writes/reads and see if you can figure where the issue is.
vsrunga
@lei1,
Hope this helps,
Vanitha
lei1
Thank you all for your replies.
Indeed, this is exactly what I was searching for.
Great, this shows my testing is not completely nonsense :)
jmjohns8
Similar problem in another thread. Bumping this one with hopes one of the previous responders can offer some insight.
https://forums.xilinx.com/t5/Memory-Interfaces-and-NoC/64-bit-SDRAM-access-from-PL-on-ZCU-102-board-reads-wrong-value/m-p/1067300
Thanks in advance!
