Artix-7 multiple DDR3
I am planning to use XC7A100Tfgg484. Is it possible to use two separate DDR3 (eg. MT41K256M32) which they work independently and can be accessed simulataneously . Is it also possible to generate such a structure using MIG.
Any help will be apprecitated, thanks.
Tags (3)
Yes, you can choose the "number of controllers" more than 1 in MIG IP wizard.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
Thanks, it helped me to get some knowledge. Appreciated
Thanks, I guess I skipped that part of MIG. Appreciated.
