DDR3 KC705 at 200 MHz with 64 bit bus
Hi ,
I tried the MIG interface for the following configuration (800 MHz , 64 bit bus ) , I am using vivado 2016.2. In the simulation I am able to read and write to the DDR3 memory. When the design is implemented and programed to the KC705 board I notice the followin g
1) Init complete is not going high
2) No app_rdy ==1 condition happens even when the app_en signal is set high .
Would appreciate any working reference model with ucf file.
With regards
Re: DDR3 KC705 at 200 MHz with 64 bit bus
It is a bit dated ( 2014 ), but there is a step-by-step guide to create a MIG design using Vivado targeting the KC705 board:
https://www.xilinx.com/support/documentation/boards_and_kits/kc705/2014_3/xtp196-kc705-mig-c-2014-3.pdf
Did you check the KC705 board to ensure the DDR SODIMM is seated correctly ( and present )?
Hey @vintu_dsi,
@timduffy is correct. This reference design even though was last verified in 2014.3 should still apply to 2016.2. You can find a sample XDC in the associated RDF found here: https://www.xilinx.com/member/forms/download/design-license.html?cid=379235&filename=rdf0281-kc705-base-trd-2014-3.zip. it is called example_top.xdc. We also have a bitsrtream ready for testing on the KC705 available in the same RDF and it is called example_top.bit.
Cory
