DDR3 device MT41J64M16-093 support
How do I determine which version of Vivado introduces support for the Micron DDR3 device MT41J64M16-093 in the Memory Interface Generator?  I would rather not have to create a custom memory from older memories but also don't want to spend the time installing multiple versions of Vivado only to find out they don't support this device and I can't find any information in release notes.  If this particular device is not supported are other -093 devices supported (i.e. larger capacity devices).
Kerry
Hello @kmwilliams
When operating at a 400MHz interface rate (2.5ns tCK) for 800Mbps operation both the old -107 speed grade part and the new -093 speed grade part have an equivalent operating point.  Protocol wise these parts have identical functional requirements since they're the same density and DQ width.  From a tools perspective selecting the existing -107 part will generate 100% compatible settings for the -093 part at 400MHz.
Hello @kmwilliams ,
I'm not sure if you're using the 7-Series MIG or an UltraScale based DDR3 controller design.
For 7-Series the IP never supported any -093 speed grade devices since these are beyond the FMAX for the IP, which is 1866Mbps for some devices and component topologies.
For UltraScale memory IP the DDR3 controller added support for the MT41J64M16TW-093 device in 2016.3.  Larger memory devices at the -093 speed grade have been supported since at least 2015.4.
Regardless of the approach for 7-Series or UltraScale it's still possible to target existing memory devices with the same device configuration (like 64M x 16 bits) as long as they have equivalent operating points at your target interface rate.  This should be pretty straight forward since the -093 speed grade is middle of the road and is pretty compatible with equivalent middle of the road or slower (higher latency devices) at lower operating points than the 2133Mbps operating point.
Using XC7A100TFGG676-1 device. MT41J64M16-107 device are no longer available. So using -093 device in its place. Speed is only 400 MHx clock
400 MHz clock (800 Mhz DDR) so within spec of Artix device. If i target a MT41J64M16-107 device in the MIG tool would i need to create a custom memory or will the settings at the clock speeds be set correctly despite using a -093 memory device.
Hello @kmwilliams
