tweber
DDR4 Interface for XAZU2EG-SFVA625
Hi there,
we are currently trying to migrate a design, originally developed on a Spartan-7, to a Zynq UltraScale+ MPSoC XAZU2EG-SFVA625. In the old design, we were using DRAM via the MIG user interface. The MIG seems to not support the UltraScale architecture at all. However, during this process we realized, that there is no DRAM interface IP provided by Vivado 2019.2, compatible to our new FPGA. Where can we get these? Do we need to install additional IP cores in Vivado?
Thanks for all information you can provide on this topic
rpr
Hi @tweber
SBVA484, SFRA484, and SFVA625 packages do not support the PL memory interface - MIG.
https://www.xilinx.com/support/documentation/data_sheets/ds925-zynq-ultrascale-plus.pdf page no 52 Note : 1
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
rpr
Hi @tweber
Ultrascale memory interface generator PG150 - UltraScale Memory Product Guide
Supports User interface and optional AXI interface.
Pratap
tweber
Thanks for this hint. We have already reviewed this document, and it describes exactly what we search for. However, the described IP seems not compatible to the XAZU2EG-SFVA625 FPGA (it would work for XAZU2EG-SFVA784 or others, though). Please see the attached screenshot from Vivado IP Catalog.
I assume the corresponding IP to the document and DDR4 is VLNV xilinx.com:ip:ddr4:2.2. Are we doing something wrong?
rpr
Hi @tweber
Pratap
bruce_karaffa
Can you use the PS DDR memory interface for your design?
tweber
That's a pity to hear, seems we have to change our FPGA or design if this is not supported on this model.
Using the PS DDR memory interface would introduce the need for a lot of changes in your design.
Anyways, thanks for your effort.
