Visitor bschwerdt
DDR4 MIG VHDL simulation in Riviera
I have a DDR4 controller that I generated in Vivado 2019.2, MIG 2.2.  I am attempting to simulate the behavioral VHDL netlist in Aldec Riviera-Pro.  The controller is sitting idle, and seemingly not finishing the initialization sequence.  Namely, port c0_ddr4_reset_n (active low) remains low, and port c0_init_calib_complete (active high) remains low.
Before the controller goes idle, there is some activity on the adr, ba, bg, cke, odt, ck_t, and ck_c pins.  Then all but the ck_t/ck_c clocks stop.  This is shown in the screen capture attached.  The capture goes to 2us, but no further activity occurs beyond that point.  I have run the simulation as long as 20ms.
Is the controller attempting to perform a calibration routine?  Isn't this supposed to be turned off for simulation?
回复: DDR4 MIG VHDL simulation in Riviera
According to pg150, only behavirol simulation is supported.
At the initial, there's the stage of calibration which cannot be turned off.
Visitor bschwerdt
How long should I expect this calibration to take?  I have run the simulation for 10s of milliseconds, and it never seems to finish calibration.
It takes less than 10us. Riviera is not t our supported third party simulator. Can you verilog behavoral simulation successfully in Vivado and other third-part simulator (Modelsim, IES, VCS Questa, etc) ?
Visitor bschwerdt
I have not tried simulating in Vivado.
The IP generator creates a _sim_netlist.vhd file.  Is this all that is needed for simulation?  I am compiling and running that.  I have successfully compiled unisim for Riviera, so I don't understand why this does not work.
Visitor bschwerdt
If the memory controller's outputs are open / undriven, does the calibration routine still complete in 10us?  Or do I need something to simulate the interactions from the DDR4 chip itself?
Mentor watari
Mentor
Hi @bschwerdt
I guess MIG requires result of calibration stage (write leveling, read leveling and adjustment of eye-pattern) if using netlist.
However, it is hard to emulate them by testbench with netlist.
So, I guess Xilinx only support behaiviour simulation without calibration stage.
Visitor bschwerdt
Interesting.  Can I generate the behavioral model without the calibration stage?  It is not immediately apparent to me how I would do that.  I don't see an option in the MIG IP generator.
No, calibration stage canno the skipped in behavirol simulation.
Visitor bschwerdt
I never got an answer to this.
No, there should be stable clock on the sys_clk intput and sys_rst should be released after sys_clk get stable.
