harmanblazex
Device Support in MIG
I am using the 7 Series MIG (Memory Interface Generator) to interface a DDR3 SODIMM. I wanted to know whether I can use a Device other than Micron (a compatible device) in my design . For eg : Could I use a Swissbit SODIMM. The device is both pin compatible and timing compatible.
Thank You in Advance.
vsrunga
You can use any DDR3 memory that is Jedec compatible
If you do not find required memory device in device memory part selection drop down you can select custom part and configure the required paramters
If you found Swissbit  SODIMM is compatible with any existing Micron part then you can select the same and go ahead
vsrunga
ashishd
For knowing Jedec compatible DDR3 memory below link can be useful
https://www.jedec.org/news/pressreleases/jedec-publishes-widely-anticipated-ddr3l-low-voltage-memory-standard
Ashish
harmanblazex
Thank You for reply.
