Visitor ssh24
FREQ_HZ and CLK_DOMIAN crossing
I am using a Tri Mode Ethernet MAC along with a AXI direct memory access in my design.
When I have my design ready, the Synthesis fails due to the errors listed below:
  • [BD 41-237] Bus Interface property FREQ_HZ does not match between /tri_mode_ethernet_mac_0/s_axis_tx(125000000) and /axi_dma_0/M_AXIS_MM2S(100000000)
  • [BD 41-237] Bus Interface property CLK_DOMAIN does not match between /tri_mode_ethernet_mac_0/s_axis_tx(/clk_wiz_clk_out1) and /axi_dma_0/M_AXIS_MM2S(design_1_processing_system7_0_0_FCLK_CLK0
The properties are locked and read only, the result is not reflected after changing the xml and xci constraints. Also Clock converters and AXI Interconnects are not effective
Awaiting your suggestions
Thank you
Teacher xilinxacct
Re: [BD 41-237] Bus Interface property FREQ_HZ does not match
Visitor ssh24
Hi @xilinxacct,
Thank you
I could somehow solve the Frequency mismatch error by changing the Processing system frequency but the Clock domain mismatch persists. I am using two different clock domains in my design which are unsynchroized.
Please find the errors below:
[BD 41-237] Bus Interface property CLK_DOMAIN does not match between /axi_smc/S01_AXI(design_1_processing_system7_0_0_FCLK_CLK0) and /axi_dma_0/M_AXI_S2MM(/tri_mode_ethernet_mac_0/rx_mac_aclk)
[BD 41-237] Bus Interface property CLK_DOMAIN does not match between /tri_mode_ethernet_mac_0/s_axis_tx(/clk_wiz_clk_out1) and /axi_dma_0/M_AXIS_MM2S(design_1_processing_system7_0_0_FCLK_CLK0)
Teacher xilinxacct
@ssh24
I'm glad the other was resolved.... Maybe this will apply to the second issue...
https://forums.xilinx.com/t5/Synthesis/Vivado-2014-2-Synthesis-Error-Bus-Interface-property-CLK-DOMAIN/m-p/552233#M13041
Hope that helps.
If so, please mark as solution accepted. Kudos also welcomed. :-)
Visitor ssh24
Hi @xilinxacct,
I believe the solution appiles only for a Vivado customized IP.
Please let me know if you find any other solution.
Thank you
