HOW TO CAPTURE DATA IN UG586
Hi Community,
Can I ask if anybody knows how Figure 1-78 in UG586 was captured ?? Did they use some kind of external equipment or some ??
I was just curious about how to capture that waveform during an actual run because I could NOT really probe those signals in Vivado ?? I think those signals are NOT part of the fabric and therefore there was NO way for me to see them in real-time action.
Thanks and,
Have a nice day,
TH
Hi @tungho_xilinx
UG586 Fig 1-78 shows simulation results at DRAM interface.
At memory interface signals runs at higher frequencies captured by using high quality scope and probes.
Yes your understanding is correct signals are not at Fabric.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Hi @tungho_xilinx
Pratap
Hi Community
Thanks for your reply. I appreciated it.
I am just curious if Xilinx also sells any scope and probes to capture memory interface signals. Or at least, what should I look into ??
Have a nice day,
TH
