Help setting IO Std for DDR4 Pins
Hello, I am a newbie with Vivado and am doing a design with DDR4. I have connected all the DDR4 IO to the BGA pins and now I'm getting some errors relating to the IO standard for certain pins. Is there a document that states what IO setting one should use for the DDR4 signals:
DDR4_act_n
DDR4_dq
DDR4_odt
DDR4_dqs
DDR4_ck
DDR4_dm
Here is an error message I get after I run the Implentation:
[DRC PORTPROP-6] I/O standard compatibility with attribute usage: Port PL_DDR4_act_n has property EQUALIZATION set, but its I/O Standard, SSTL12_DCI, does not support this property.
[DRC PORTPROP-6] I/O standard compatibility with attribute usage: Port PL_DDR4_act_n has property OFFSET_CNTRL set, but its I/O Standard, SSTL12_DCI, does not support this property.
[DRC PORTPROP-6] I/O standard compatibility with attribute usage: Port PL_DDR4_act_n has property PRE_EMPHASIS set, but its I/O Standard, SSTL12_DCI, does not support this property.
I need some help getting rid of this error message and help configuring the DDR4 pins to the appropriate IO settings.
Thank you very much,
Joe
Re: Help setting IO Std for DDR4 Pins
Hello @joe306 ,
The most easiest way is to refer an example design.
Do you use an UltraScale/UltraScale+ device?  If so, the example design is described in the PG150, from page.242.
https://www.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_4/pg150-ultrascale-memory-ip.pdf
UG571 explains the select io like SSTL_12_DCI, so it would be useful.
https://www.xilinx.com/support/documentation/user_guides/ug571-ultrascale-selectio.pdf
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
Hello @joe306 ,
Kshimizu
回复: Help setting IO Std for DDR4 Pins
As you have DDR4 IP in your design, the IO standard contraints are created by IP. You only have to assign the memroy IO location constraints in your top xdc file.
Thank you very much.
