Anonymous
Not applicable
How to support multi-rank?
Hi all,
   Our company will build a system, that holds an amount of 16GB data. For bandwith reasons we have to use multi-rank LRDIMMs, and I get the message form the  ds176_7Series_MIS that it is only Single rank UDIMM, RDIMM, and SODIMM
support. So How to support multi-rank?  thanks  !!!
best regards,
weili
Voyager
Voyager
dual rank is support in 14.4.
Anonymous
Not applicable
Could 14.4 suport  four ranks?   How to support  it ?  I  have modified the  parameter ,but  ISE report error.
Vivado/ISE supports only dual rank DIMMs, there is no plan to support quad rank for 7 series.
Anonymous
Not applicable
Thanks ,but  we  must support  LRDIMM project ,so  we have modified the PHY_init  file to support  the LRDIMMs , and  I want to  ask  how could I  modify?
As Xilinx do not  officially support multi(quad) rank DIMMs there is no proven/documnted flow for phy block changes.
Also quad rank devices were not HW evaluated and hence we cannot assure that your changes would work.
I would suggest you to contact your FAE, he might do the needful or guide you accordingly.
