whitleda
Incorrect CS_N Width for Dual-rank DDR3
Currently getting the following error when trying synthesize MIG for a dual-rank SODIMM:
[Synth 8-549] port width mismatch for port 'c0_ddr3_cs_n': port width = 2, actual width = 1 ["E:/work/HDL/trunk/FDK/projects/XPedite2500/MIG/MIG.srcs/sources_1/bd/design_1/hdl/design_1.vhd":87]
I see the other control signal widths are at 2 as expected but it appears CS_N still only has a width of 1.  Appears to be a bug in the MIG block.
yenigal
Which version of MIG and Vivado are you using?
Is this issue seen with example design of MIG also when generated from IP catalog also or only seen with block design.
Satish
whitleda
Vivado 2014.4.1
MIG 6.1
Only seen in block design.
