Is this DDR3 setup possible with MIG / ARTIX 7?
According to some other forum posts & UG586, when using multiple DDR3 components on a single MIG generated controller, ALL address/control/clk signals  (including LDQx) excpet DQx are shared on the DDR3 components. Is this assumption correct?
Attached the setup I'm planning to implement - 2 x DDR3 x 16 to form a 32 bit wide memory block.
Any advice / feedback would be much appreciated.
Thanks, best regards
Mike
When you select a X16 component and increase the Data witdth to 32, MIG assumes there are two X16 components, it shares all address and control signals but I think not Data strobes.
Please generate MIG for your set up and observe the pinout in user_design/par folder against yours
Hope this helps
Vanitha
Hope this helps
Vanitha
Thanks again for your valuable help - indeed the pin assignment is already done by MIG, located in a seperate constraints file.
I was not aware of that, as I could not see any connections done in the main project ucf.
Mike
