Heisenberg_M
KINTEX Ultra scale-DDR4 Data Read mode simulation problem: 1 model, 2 results?
I use the ibis model to do data read mode simulation in Hyperlynx and Keysight ADS respectively. (signal from DDR4 SDRAM to Xilinx FPGA)
The result confounded me. The waveform in ADS is pretty good, while too bad in Hyperlynx. Besides, I found that data read waveform differs with/without PE2400.
What I mentioned above was illustrated by 4  figures attached below.
Is it normal for Xilinx read mode model?  Which one I can believe, ADS or Hyperlynx?
Thanks!
topology in Hyperlynx.pngWaveform in Hyperlynx.pngTopology in ADS.pngWaveform in ADS.png
frank_ma
Your setting of Kintex IBIS Model is wrong in ADS schematic.
You should set Kintex IBIS as Input, and connect to the input pin of the IBIS.
calebd
@Heisenberg_M
Does frank_ma's response answer your question fully?  If so, could you please accept that as the solution?  Otherwise, can you elaborate if this question was not resolved?
Caleb
Versal Blogs
Heisenberg_M
Thanks for your reply,  frank_ma!
The setting of Kintex Ibis model in ADS is right. The Kintex model is a IO model, so it appears different from Hyperlynx.
You can try it in ADS.
