Visitor ajivs
Kintex 7 Schematic Review- Memory Interface
Please help to review the schematics for DDR3 & NOR flash interface with XC7K160T-3FFG676.
Aji
Re: Kintex 7 Schematic Review- Memory Interface
Hello @ajivs,
The QSPIs look fine.
For the DDR3 I noticed you have the external VREF pins connected on the banks but you have your VRP/VRN resistors configured for 50-ohm trace impedances.  I just wanted to point out that if you're going faster than 1333Mbps then you should have 40-ohm traces and setup your VRP/VRN resistors for 40-ohm traces (80-ohm values).  If you're below 1333Mbps then double check your current layout to make sure they're targeting 50-ohm traces.
For the DDR3 clock I'm not sure why you have two types of termination.  Remove the 100-ohm across the FPGA output DDR3_CLK_P/N pins.  The correct termination is already done with the in-line resistors on the single ended components.
