SD
MIG DDR4 example design RDIMM M393A8K40B21-CTC
Hello Everyone,
I have faced with a problem of using MIG DDR4 controller "Example design" together with RDIMM M393A8K40B21-CTC.
I have a custom board with an XCKU060-2FFVA1156E and DDR4 DIMM. The board is done following the
recommendations from PG150.
The memory module is used not original Samsung, but NEMIX MR19200-944 64GB 2400MHz 2Rx4, which is a replica.
The problem is that the calibration of the MIG controller does not pass, same situation on several boards.
The error is shown: writing leveling "Could not find stable 0. Error found on Rank0, Byte 1".
The data lines on the PCB are aligned as follows:
The DIMM data bus is grouped by nibbles:
- address and command lines are aligned to the clock with a tolerance of +/- 1.19mm
- the length of the strobe lines dqs differ from the clocks by no more than +/- 22.4mm
- the data inside the nibbles is aligned to its gate with a tolerance of +/- 1.47mm
- clocks and strobes inside the diffpair are aligned with a tolerance of 0.15 mm
- the difference between the lengths of the conductors between the nibbles is in the range of 47.74mm
- the spread of the lengths of the conductors of nibbles lies in the range of 66mm-112mm
I checked the DIMM connection and voltages - everything seems to be in order.
There is no timing violations, no errors/critical warning, I'm using an example design with debug on.
Please, advise, what direction to look to solve the problem.
Тhanks.
kren
Please check the pinout of the DDR4 interface according to our board layout. Also refer to "hardware debug" section in the document pg150.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
