sheladiya_vijay
MIG Simulation: ERROR: Activate Failure. Initialization sequence is not complete
I'm trying to simulate 7 Series MIG generated using Vivado 2013.4 for XC7K160T device and MT16JTF51264HZ-1G SODIMM module.
I tried it by simulating it standalone using Modelsim 10.2c, without Vivado. I also tried it with Vivado. But it gives same error like: "ERROR: Activate  Failure.  Initialization sequence is not complete".
Vijay
vsrunga
So in which case the error occurs?
If this is in your full design and you are using your own test becnh did you check if test bench maps the model correctly as in sim_tb_top?
Are all the top level parameters cross checked and hierarchy of the files is correct?
did you see any phy end FPGA signals toggling in simulation or in underterminate or high impedance state?
yenigal
Is this issue seen with MIG example design simulation or MIG with your own testbench.
Have you generated the MIG simulation model during core generation.
Satish
sheladiya_vijay
Hi Satish,
I simulated MIG example design, it goes well without any issue. I tried it with Vivado Simulator and Modelsim as well.
Yes, I have generated memory model during core generation.
Vijay
vsrunga
sheladiya_vijay
Hi vsrunga,
You are right...I cross checked my design with example design and I found that there was a wrong assignment to ddr3_addr_sdram and ddr3_ba_sdram. I corrected it and it is working fine now.
Thanks all...
Vijay
