08-26-2011 04:43 AM
Hi.
I have a little trouble about using the MIG to write/read the sdram chip EDE2516ABSE.I recently published a similar post:http://forums.xilinx.com/t5/MIG-Memory-Interface-Generator/Create-Custom-Part/td-p/171380.
And I so sorry not to reply it.Then I try to build a project and create a custom memory part base on EDE5116AXXX-8E .Parameter:
trcd and trp is 12.
And I use the ChipScope to monitor the signal.Here is the waveform:
you can see I write some data to the sdram after calib_done success.But the trouble is the data I read from the MCB is a little different to the data I had wrote.For example,the first data is 64'h31302f2e2d2c2b2a,but I read out 64'h31302f2c2d2c2b28!(I use to 64 bit port)
It's looks like every 1st and 5th byte data are error.
I also download the example_design,I think it can write/read correctly.
So,what's wrong with my project?or ChipScope set?
Thanks!
08-26-2011 08:17 PM - edited 08-26-2011 08:24 PM
Do you have more than one circuit board?
If yes, do all the circuit boards behave the same?
Have you tried a number of different data patterns, to try to correlate the error with data pattern, address pattern, etc. etc.?
What other data patterns have you tested?
-- Bob Elkind
08-26-2011 04:49 AM
Datasheet of EDE2516:http://www.elpida.com/en/products/eol/ddr2.html
08-26-2011 07:46 AM
Three questions:
-- Bob Elkind
08-26-2011 07:00 PM - edited 08-26-2011 07:05 PM
Hi,Bob
What FPGA device are you targeting?
I use xc6slx16-3csg324
Have you seen similar results on other copies of this board?
I have seen a topic of " DDR2 Data Errors"http://forums.xilinx.com/t5/MIG-Memory-Interface-Generator/DDR2-Data-Errors/td-p/165932.
But I think my situation is different with him.
What data patterns have you tested?
I write the test data in the port c3_p0_wr_data,and read from port c3_p1_rd_data.
The port p0's timing here:
**************************timing**********************************************
c3_clk0 _/ ̄\_/ ̄\_/ ̄\_/ ̄\_/ ̄\_/ ̄\_/ ̄\_/ ̄\_/ ̄\_......
wr_8bit_data =><00><01.><02><03.><04><05.><06><07.><08><09>....
c3_p0_wr_en __________________.../ ̄\___
c3_p0_wr_dataXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX<0706050403020100>
c3_p0_wr_en ___/ ̄\__/ ̄\__/ ̄\__/ ̄\_______
c3_p0_wr_data --<=00=><=01=><=10=><=11=><=00=>---------
c3_p0_cmd_en ______________/ ̄\_____
c3_p0_byte_addr<=====00000000===========><00000020
c3_p1_cmd_en ________________/ ̄\__
*************************code*************************************
assign c3_p0_cmd_instr = 3'b000;
assign c3_p0_cmd_bl = 6'h03;
assign c3_p0_wr_mask = 0;
always @ (posedge c3_clk0,posedge c3_rst0)
if(c3_rst0)
wr_current <= WR_IDLE;
else wr_current <= wr_next;
always @ *
case(wr_current)
WR_IDLE:if(wr_en)wr_next = WR_1ST;else wr_next = WR_IDLE;
WR_1ST:if(!fifo_empty)wr_next = WR_2nd;else wr_next = WR_1ST;
WR_2nd:if(!fifo_empty)wr_next = WR_3th;else wr_next = WR_2nd;
WR_3th:if(!fifo_empty)wr_next = WR_4th;else wr_next = WR_3th;
WR_4th:if(!fifo_empty)wr_next = WR_5th;else wr_next = WR_4th;
WR_5th:if(!fifo_empty)wr_next = WR_6th;else wr_next = WR_5th;
WR_6th:if(!fifo_empty)wr_next = WR_7th;else wr_next = WR_6th;
WR_7th:if(!fifo_empty)wr_next = WR_8th;else wr_next = WR_7th;
WR_8th:if(wr_en)wr_next = WR_1ST;
default:wr_next = WR_IDLE;
endcase
always @ (posedge c3_clk0)
case(wr_next)
WR_1ST:c3_p0_wr_data[7:0] <= wr_8bit_data;
WR_2nd:c3_p0_wr_data[15:8] <= wr_8bit_data;
WR_3th:c3_p0_wr_data[23:16] <= wr_8bit_data;
WR_4th:c3_p0_wr_data[31:24] <= wr_8bit_data;
WR_5th:c3_p0_wr_data[39:32] <= wr_8bit_data;
WR_6th:c3_p0_wr_data[47:40] <= wr_8bit_data;
WR_7th:c3_p0_wr_data[55:48] <= wr_8bit_data;
WR_8th:c3_p0_wr_data[63:56] <= wr_8bit_data;
default:;
endcase
if(wr_next == WR_8th)
c3_p0_wr_en <= 1'b1;
else c3_p0_wr_en <= 1'b0;
p0 address:
if(c3_rst0)
wr_addr <= 30'h0;
else if((c3_calib_done) & (c3_p0_cmd_en))
wr_addr <= wr_addr + ADDR_INC; //ADDR_INC = 'h20
And p1:
assign c3_p1_cmd_byte_addr = wr_addr - 2 * ADDR_INC;
assign c3_p0_rd_en = ~ c3_p1_rd_empty;
assign c3_p0_cmd_instr = 3'b001;
So you can see I write the data to c3_p0_wr_data as: 64'h21201f1e1d1c1b1a.
But I read the data from c3_p1_rd_data is: 64'h21201f1c1d1c1b18.
-- Bob Elkind
08-26-2011 10:23 PM
Thank you very much,Bob.
Yeah,I replaced another circuit board,and I can read correct data!
08-26-2011 11:56 PM - edited 08-27-2011 12:03 AM
I wonderful that the example_design write the datas as 'h00000200,'h00000208,''h00000210...
So that I use the example_design to test my old sdram which one can not work properly, it cann't find the error,because it dosen't test the lowest 3 bits(unfortunately,they are broken).
And I interested in why only the lowest 3 bits are broken?
08-27-2011 04:36 AM
You have very clearly and dramatically demonstrated the value of building multiple copies of a new and untested board design. This has saved you countless hours of design debugging for a problem which you have now proven to be a component or assembly fault. Well done!
The generic answer to 'what is the cause of failure': either component failure or assembly failure.
More often than not, the cause is assembly failure (or damage) rather than component failure. Visually inspect the board for broken traces or solder whiskers. Have the board cleaned. With the board grounded on an anti-static mat, blow some air across it. Check for missing or misaligned components (e.g. decoupling caps). Check voltage supplies with an oscilloscope. See if the board works properly.
If the board is still failing, and if the board is valuable to you, try replacing the DRAM on the board. If still broken, try replacing the FPGA on the board.
-- Bob Elkind
08-27-2011 09:16 AM
Thanks,Bob.
I will follow these methods to solution the problems later.
