johnwcherry4
Manually synthesize the MIG IP
In reference to answer record # 63463, how would I manually synthesize the MIG IP in the Vivado GUI.
John
vsrunga
Please check below link
http://www.xilinx.com/support/answers/57546.html
Hope this helps,
-Vanitha
vsrunga
Hope this helps,
-Vanitha
johnwcherry4
Vanitha,
That worked thanks
John
