Mahender
PS vs PL DRAM of zcu111
    I want to store the data in dram based on the address we given and both read and write functions needed. For this task which one I have to choose whether PL side or PS side ram..?(I am using zcu111 board).
What are the differences between PL side and PS side ram.
What features are different(ex: latency,storage capacity etc..,)?
Thanks in advance ....!
rpr
Hi @Mahender
PS Description:
4 GByte 260-pin DDR4 SODIMM
Single rank x16 512 Mbit x 64-bit
Supports 1333 MT/s – 2666 MT/s
https://www.xilinx.com/support/documentation/user_guides/ug1085-zynq-ultrascale-trm.pdf
PL Description:
8 Gb (512 Mb x 16) DDR4-2666
https://www.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_4/pg150-ultrascale-memory-ip.pdf
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
rpr
Hi @Mahender
PS Description:
PL Description:
Pratap
