Ping - Pong DDR3 Memory Controller with AXI4 Interface
I generated a DDR3 MIG IP with ping-pong enabled.  How can I have a AXI4 interface?
Jacques
Only DDR3 Ping-Pong PHY is supported. Pleae design with your own controller and interface with the PHY signals.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
