arnelln
S6 MCB ARB_TIME_SLOT settings
I've used MIG to generate a DDR2 memory controller with 4 ports (0,2,3,4) with round robin arbitration, but am a bit confused with the generated code.
The top level of the MIG design has the following for the ARB_TIME_SLOT settings, and that looks as expected:
   constant C1_ARB_TIME_SLOT_0      : bit_vector(11 downto 0) := o"0234";
   constant C1_ARB_TIME_SLOT_1      : bit_vector(11 downto 0) := o"2340";
   constant C1_ARB_TIME_SLOT_2      : bit_vector(11 downto 0) := o"3402";
   constant C1_ARB_TIME_SLOT_3      : bit_vector(11 downto 0) := o"4023";
   constant C1_ARB_TIME_SLOT_4      : bit_vector(11 downto 0) := o"0234";
   constant C1_ARB_TIME_SLOT_5      : bit_vector(11 downto 0) := o"2340";
   constant C1_ARB_TIME_SLOT_6      : bit_vector(11 downto 0) := o"3402";
   constant C1_ARB_TIME_SLOT_7      : bit_vector(11 downto 0) := o"4023";
   constant C1_ARB_TIME_SLOT_8      : bit_vector(11 downto 0) := o"0234";
   constant C1_ARB_TIME_SLOT_9      : bit_vector(11 downto 0) := o"2340";
   constant C1_ARB_TIME_SLOT_10     : bit_vector(11 downto 0) := o"3402";
   constant C1_ARB_TIME_SLOT_11     : bit_vector(11 downto 0) := o"4023";
Then when I go down to the memc1_wrapper.vhd file it maps them as:
constant ARB_TIME_SLOT_0    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_0(11 downto 9) & C_ARB_TIME_SLOT_0(8 downto 6) & C_ARB_TIME_SLOT_0(5 downto 3) & C_ARB_TIME_SLOT_0(2 downto 0));
constant ARB_TIME_SLOT_1    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_1(11 downto 9) & C_ARB_TIME_SLOT_1(8 downto 6) & C_ARB_TIME_SLOT_1(5 downto 3) & C_ARB_TIME_SLOT_1(2 downto 0));
constant ARB_TIME_SLOT_2    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_2(11 downto 9) & C_ARB_TIME_SLOT_2(8 downto 6) & C_ARB_TIME_SLOT_2(5 downto 3) & C_ARB_TIME_SLOT_2(2 downto 0));
constant ARB_TIME_SLOT_3    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_3(11 downto 9) & C_ARB_TIME_SLOT_3(8 downto 6) & C_ARB_TIME_SLOT_3(5 downto 3) & C_ARB_TIME_SLOT_3(2 downto 0));
constant ARB_TIME_SLOT_4    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_4(11 downto 9) & C_ARB_TIME_SLOT_4(8 downto 6) & C_ARB_TIME_SLOT_4(5 downto 3) & C_ARB_TIME_SLOT_4(2 downto 0));
constant ARB_TIME_SLOT_5    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_5(11 downto 9) & C_ARB_TIME_SLOT_5(8 downto 6) & C_ARB_TIME_SLOT_5(5 downto 3) & C_ARB_TIME_SLOT_5(2 downto 0));
constant ARB_TIME_SLOT_6    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_6(11 downto 9) & C_ARB_TIME_SLOT_6(8 downto 6) & C_ARB_TIME_SLOT_6(5 downto 3) & C_ARB_TIME_SLOT_6(2 downto 0));
constant ARB_TIME_SLOT_7    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_7(11 downto 9) & C_ARB_TIME_SLOT_7(8 downto 6) & C_ARB_TIME_SLOT_7(5 downto 3) & C_ARB_TIME_SLOT_7(2 downto 0));
constant ARB_TIME_SLOT_8    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_8(11 downto 9) & C_ARB_TIME_SLOT_8(8 downto 6) & C_ARB_TIME_SLOT_8(5 downto 3) & C_ARB_TIME_SLOT_8(2 downto 0));
constant ARB_TIME_SLOT_9    : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_9(11 downto 9) & C_ARB_TIME_SLOT_9(8 downto 6) & C_ARB_TIME_SLOT_9(5 downto 3) & C_ARB_TIME_SLOT_9(2 downto 0));
constant ARB_TIME_SLOT_10   : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_10(11 downto 9) & C_ARB_TIME_SLOT_10(8 downto 6) & C_ARB_TIME_SLOT_10(5 downto 3) & C_ARB_TIME_SLOT_10(2 downto 0));
constant ARB_TIME_SLOT_11   : bit_vector(17 downto 0) := ("000" & "000" & C_ARB_TIME_SLOT_11(11 downto 9) & C_ARB_TIME_SLOT_11(8 downto 6) & C_ARB_TIME_SLOT_11(5 downto 3) & C_ARB_TIME_SLOT_11(2 downto 0));
This is where I get confused, as according to UG388 this appears to be setting port 0 as the highest priority for all time slots.  Here is the description from ug388 for the ARB_TIME_SLOT values:
These 6-digit octal (18-bit) values set the port priority for each time slot.
Possible Values:
For example, C_ARB_TIME_SLOT0 = 18'o012345 (sets Port 0 with the highest priority down to Port 5 with the lowest
priority).
Can anyone confirm if the problem is with ug388, or MIG, or am I just getting confused?
robinliuy
C_ARB_TIME_SLOT_x has 18 bits width. If you use 4 ports, highest 6 bits are not used. If you use 5 ports, highest 3 bits are not used. Tool assign all 0x0 to unused bits. So, in your case, C_ARB_TIME_SLOT0 can be considered as o"xx0234". xx means arbiter does not care. Only last four digits are considered.
robinliuy
arnelln
Thanks, that makes sense now.  It would be nice if it was documented somewhere, as I couldn't find it anywhere.
