Sub-Optimal placement for CCIO and MMCM Pair
Hi Guys,
Im am trying to use the VC709 and both DDR banks, but I get this error that says:
[Place 30-575] Sub-optimal placement for a clock-capable IO pin and MMCM pair. If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING.
Any ideas? Im totaly stumped on this one!
PS. for a more detailed error see attachment.
Thank you!
As you are using VC709 follow the below doc and check if your pin constraint are correct.
http://www.xilinx.com/support/documentation/boards_and_kits/vc709/2014_4/xtp235-vc709-mig-c-2014-4.pdf
You can also download the design files from below link
http://www.xilinx.com/products/boards-and-kits/dk-v7-vc709-g.html#documentation
Satish
