Ultrascale DDR4 DQS PCB Design Guidelines
The UG583 Ultrascale design guidelines specify 66 Ohms for DQS differential impedance with DIMMs (p. 81). Other sections specify a DQS differential impedance of 76 to 90 Ohms (p. 68) with DRAM soldered down. Why is the DQS differential impedance lower for DIMMs? Other SoC memory controllers typically specify a higher impedance for L1 and L2 (~85 Ohms).
We recommend 66 ohm DQS with a DIMM because of the series resistors on the DIMM.
We have run simulations to confirm this.
Thank you,
Sam
In both cases the breakout is 86 ohms.  I am working on getting an answer as to why we recommend 66 ohms for DIMM and 76 ohms for components.
Thank you,
Sam
Thank you,
Sam
Thanks for the prompt reply!
