kalhana_oa
Zynq Ultrascale+ PS LPDDR4 byte group skew
I'm doing a design with Zynq Ultrascale+ with LPDDR4 on the PS side (I'm using a single 2GB LPDDR4 IC which has dual die and 32-bit bus - Micron MT53D512M32D2DS-046).
In UG583 (v1.18), page 96, Table 2-45 it mentions the skew constraints.
In the 2nd row of the table, it mentions "Data (DQ/DM) to DQS (A)" and "Data (DQ/DM) to DQS (B)" should be ±5ps.
My question is, does this mean that all the data/strobe/mask in channel A (and B) have to be matched as opposed to each byte group separately (16-bit data groups matched in each channel)?
If so, that's harder to do than the usual DDR skew matching where only 8-bit byte groups are separately matched without any dependence between them.
So you end up with 2 groups of 16bit data skew matched as opposed to 4 groups of 8-bit data?
rpr
Hi @kalhana_oa
LPDDR4 Channel A and channel B are independent, so there is no skew dependent between them. So you can group bytes of channel A and channel B separately.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
kalhana_oa
Yes, but channel A has 2 bytes and channel B has 2 bytes. Does this mean both bytes in channel A has to have the same skew?
wouter81
My expectation: 5ps matching should be done per byte group. This is unclear in the User Guide. Hopefully someone can clear this up. And update ug583.
dan1
Is there an official answer from Xilinx on this issue yet? I am also stuck.
I've attached an image that illustrates my interpretation of Table 2-45 on page 96 of the PCB Design Guide.
Red indicates what is unknown to me, and the confusion is mostly brought about by the 4th row of the table.
Note that I have only drawn a single channel since they are tuned independently.
