Visitor abfontao
cmd_en behavior
Hi all.
Just in case anyone has happen to be suffering the same problem and knows any solution / suggestion.
When I drive a cmd_en pulse on my mig-based design, I am supposed to be popping an instruction onto the command fifo. In my case, I'm reading from the SDRAM, using a 64-word burst and starting from the address 0. Once this pulse has been issued, the MCB should start to pop data into the reading FIFO... but.... in my case it never does.
I wait for the calib_done signal to be asserted before issuing the cmd_en pulse.
You can see it in the chipscope monitoring image attached.
Any idea on why the reading process never starts?
Visitor abfontao
Re: cmd_en behavior
After testing it: I can confirm what I posted before: the calib_done signal is asserted twice and during the first assertion, any command will be ignored.
Is it a design error?
Teacher rcingham
Re: cmd_en behavior
What FPGA?
Which version of ISE and MIG?
Visitor abfontao
Re: cmd_en behavior
FPGA: XC6SLX45T (on a SP605 board).
ISE: 13.2.
MIG: 3.8.
Instructor
Instructor
Re: cmd_en behavior
I believe the read latency is roughly 22 cycles.  I'm not sure that your simulation extends long enough.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor abfontao
Re: cmd_en behavior
Yes, it does:
Visitor abfontao
Re: cmd_en behavior
Does it make sense that the c3_calib_done signal is asserted twice (erroneously) and during the first assertion all operations send to the MCB are not taken into account or end in failure?
This post seem to support my theory:
http://forums.xilinx.com/t5/MIG-Memory-Interface-Generator/DDR3-on-SP605-spartan-6-Incorrect-calibration-gt-calib-done/m-p/159034
I'll test it and post the results here.
Thanks everyone.
Visitor abfontao
Re: cmd_en behavior
Instructor
Instructor
Re: cmd_en behavior
This is a good problem to submit for webcase support.  If it's a bug, you'll need to open a webcase anyway.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor abfontao
Re: cmd_en behavior
Webcase submitted. Waiting for the reply. I'll keep you informed if I get a possitive answer.
Visitor gicquiaux515
Re: cmd_en behavior
ok thanks to keep us informed.
